I got most of the stuff installed for my backup camera, the screen works, and the backup lines on the screen appear when I shift into reverse. I just don't get a live image from the camera... I took some pictures of the wires in question which I feel could be causing the problem since they are not connected to anything (The bundle of wires in the first pic is connected to the camera itself from the trunk handle)
I currently have one red wire by the glove box which is not connected (see pic 3) and then towards the rear of the car I have one ground and one red wire which are not connected. I'm guessing I need to tap into a power source for the front red wire into the fuse box and another power and ground wire in the back for the other two wires in question, will the reverse light work for the back? For the front- What kind of fuse should I look for? (always on, engine on only, aux?)
Thanks,
