Agreed, although I certainly respect Zandrew, I know him and I debated the merits of Comp turbos as he had had one fail on him apparently, and my response to him was "well, if they fail that often, then there should be no shortage of reports online" As recall he was had pressed to find just about any failures.
There MAY have been some initial failures in the V1.0 oilless type. But having gotten to their 3rd generation, I would think they have a pretty good idea as to how well they last. Remember, these guys STARTED by making full out race turbos.
Also, as I can say with certainty from my own experiences, that dual front ball bearing setup taking the axial thrust loading in both directions makes them virtually indestructible. (At least the triplex variety)
Regarding how often you need to re-grease them, it's not very often. On the order of every 6 months or so? That, and when you look at the CHRA, there isn't exactly a lot of room for grease period. So $10,000/Kg or not, if you only need a ketchup package worth, it's a bit of a moot point no?
I think what we're all starting to veer off on though is the possibilities and MAJOR MAJOR simplifications this brings to rear Mount turbo set-ups. Basically all you need to do is run your turbine and compressor piping fore and aft, wastegates and DV lines and that's it. (and tuning and feeling of course).
What terrifies me about running 10 feet of oil lines under the car is the possibility of a leak or strike or snag which results in the line being compromised. In which case, there goes your built engine, AND turbo.... Plus the extra added expense of getting it to drain right as memory serves, don't you need to actively pump all the drain oil back into the engine sump? (again, another possible failure point).
It's be great if AEM could be bothered to make a ready made Infinity unit that could be used with ME7.1.1 and retain the CAN-BUS functionality, but while I'm dreaming why not ask for a pony as well
