Results 1 to 21 of 21
    Sep 08 2019
    Romania
    RS5 B9 aftermarket performance brake pads
    Hello,
    I suppose I'm not the only one that is not happy with the brake pads in the RS5.
    I was wondering if somebody found an option for a performance brake pad that would work well with the OEM iron discs.
    In the past I owned an Audi RS6 C7 and found that the best pad for the iron brakes is Endless MX72 but got in contact with Endless and they do not offer yet this pad for the RS5 B9.
    The only options I found until now are:
    - O-Brake from Germany but there is no reviews on them and they suggest to replace also the disc with a bigger diameter. they make HTCIC brake discs and pads.
    - EBC yellor or red but read poor reviews about them
    - Centric Posi Quiet PRO for the front and Posi Quiet (without PRO) for the back
    - ATE normal brake pads for the front and ceramic pads for the back
    - I-Sweep with allot of ranges but also not much reviews about them
    If somebody found an option or have tested one of the options above please give us some feedback.
    thank you in advance
    Remus
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by RemusCotut View Post
    Hello,
    Remus
    I just started my search for pads cause they squeak like crazy when coming to a stop and the dust is ridiculous. I recently got some 3 piece wheels and for my sanity I think i need a pad that dusts way less. So I had a C7 S7 and changed the pads to EBC Red stuff, and loved them. They didn't squeak and were low on the dust. I didn't know they were available for our cars. I may give them a shot.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Established Member Two Rings Jwkc's Avatar
    Dec 14 2018
    Sky
    Endless Mx72 pads are available for the Application of B9 RS4/RS5 S4/S5 in Asia
    May be you can check this reference :EIP293MX72 for Front . Dixcel Z 13522308 for rear
    Dec 14 2018
    Sky
    Sep 08 2019
    Romania
    thank you very much. I will ask the European distributor.
    Senior Member Three Rings c99's Avatar
    Feb 28 2009
    RS5 2.9TFSI - dead engine
    EU, CZ
    When You are from EU, I would buy OZ Zimmermann (Germany), they offer pads and rotors too.
    https://www.otto-zimmermann.de/
    Rear:
    Front:
    Senior Member Two Rings IamRacer X's Avatar
    Sep 26 2019
    Jupiter, FL
    Tire rack shows these available in the US market
    https://m.tirerack.com/brakes/result...tandard+Brakes
    Sep 08 2019
    Romania
    I can confirm availability in US.
    I just placed the order today at speedfreakusa.com
    - - - Updated - - -
    Endless MX72 front and rear pads
    Established Member Two Rings totaro's Avatar
    Jul 13 2009
    SF Bay Area
    $1090 for a set of Endless brake pads? really?
    Sep 08 2019
    Romania
    actually it's 895$ but from my past experience with this pad is worth all the money.
    Established Member Two Rings penguiNET's Avatar
    Sep 12 2019
    Bay Area, California
    Hi, I'm not familiar with this pad. Could you tell us please what makes it worth it? What makes it so good?
    Thanks
    Feb 01 2016
    Encinitas, CA
    $895 for pads is kind of ridiculous!!!
    Sep 08 2019
    Romania
    Quote Originally Posted by penguiNET View Post
    Thanks
    Hello,
    From my point of view this is an ideal pad for fast street driving but not only.
    I had an Audi RS6 C7 which is known as a poor brake setup due to undersized discs, allot of brake dust and noise.
    When I changed to Endless MX72 I got the following situation:
    - disc wear is practically not existing anymore (the pads deposit a bluish coating on the disc and generate a mirror finish on the disc)
    - there is almost no dust at all due to the ceramic composition of the pad
    - the discs do not wrap anymore with this pad
    - the pad is not fading in sprinted drives due to 700 degree celsius temperature range
    - there is no noise if the pad is bedded in as per instructions of Endless
    the only downside of the pad is on the very cold weather the first bite of the brake is not ideal.
    what else could you want from a pad for street driving.
    and by the way Endless is one of the most reputable brake pad supplier in the WRC.
    Jul 21 2004
    South Florida
    Im running the z23 ceramic pads on the rear. Ther are gg temperature rated and holding up much better than the oem ferodo pads to 130mph to 20mph braking. Im going with the reybestos gg rated front ceramics in a month. The rears are giving no dust, very mild wear, no noise, and yeah ceramic pads apperar to almost polish the rotors as they go. Iirc the pads are like 50 bucks too.
    Mike
    2018 Audi S5
    Gone-
    Sep 26 2019
    Jupiter, FL
    Quote Originally Posted by bhvrdr View Post
    Mike
    Good info. On a side note, I live in south Florida too. Where do you do your drag racing? PBIR?
    Current
    2019 RS5 Sportback Nardo
    Original Owner
    2003 Corvette Z06
    LS3, Coilovers, BBK, Track/Street
    2022 Jeep Wrangler
    High Altitude
    Jul 21 2004
    South Florida
    Quote Originally Posted by IamRacer X View Post
    Yeah pbir for drag and roadcouse. Sebring for more roadcourse. Back roads by beeline for draggy runs.
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Feb 28 2009
    EU, CZ
    Cold weather (better cold brakes) the first brake is not "ideal" - so like every racing pads, very dangerous in real life situations, most braking is done with cold brakes
    and no R90 homologation, so no homologation for use in the streets of EU.
    So not for me.
    Junior Member One Ring
    Dec 29 2020
    Lancaster, CA
    Quote Originally Posted by Djpeaksd View Post
    Still trying to find a solution over OEM noisy and most annoying DUSTY brake pads,... EBC RedStuff good with comparable or better braking? Anyone else offer experience with other available pads? Not much is offered yet for our B9/B9.5's yet...
    Junior Member Two Rings
    Oct 03 2018
    Romania
    I have used EBC Yellow pads on different cars and I vouch for them, wouldn`t use anything else (also tried Ferodo DS2500, Brembo High Performance stuff); can`t beat price / performance ratio on them.
    Veteran Member Three Rings Dan99's Avatar
    Feb 09 2019
    Chicago Area
    The reviews on the rotors weren't great...
    Aug 13 2008
    Reston, VA
    I've tried many ceramic pads (hawk, ebc red and yellow, akibono)
    Great for low dust
    But none compare to the braking ability of the oem pads
    So I'll take the dust, especially on a car like the RS5 where you will be driving at high speeds
