Results 1 to 8 of 8
    Veteran Member Three Rings coop3422's Avatar
    Jan 11 2019
    Calgary
    Windshield wipers - that extra wipe at the end
    This probably seems random, but my wipers drive me crazy. Being in Canada, we've had a bit of snow already, leading to sloppy roads.
    I'll spray my windows, it'll wipe 3 times and be clean. Then 5-10 seconds later it automatically does a follow up swipe and streaks the crap out of my windshield. It bugs the crap out of me because I like a clean windshield.
    Am I the only one this bugs? Is there a way to turn off that extra, delayed wipe?
    Also as an aside, is there a common wiper people like to run? Think I'm gonna order some new ones.
    Thanks
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    If not mistaken the afterwhipe can be turned off with vcds/obdeleven, but don't quote me on that. But i think i have seen it between the codes i think.
    Personally i like it as often there is still some left over water that gets whiped off with that extra whip.
    Maybe you need a new set of whipers or you have something on your windshield (rainX) or something in your water?
    Can't go wrong with the Bosh aero ones (or how they are called). Ideally you better replace them yearly before winter.
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Jun 09 2017
    Signature
    GTA
    I believe it can be turned of f with Vagcom too.
    Like Dasquade tho, I actually like the feature because there is usually some fluid running down from the top portion of the windshield after the three wipes, the delayed final wipe gets it. I actually enabled it with Vagcom on my Golf to do the delayed final wipe on both the front and rear wipers..
    You could also try a different brand of washer fluid that may not streak or streak as much..
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    Interesting. I've always appreciated the final, delayed swipe, as it clears away the overage from the prior three.
    My guess is that you'll enjoy much better performance & results with fresh wiper blades. I've run Bosch Icon (on several different vehicles) and have been pleased. I count myself lucky if I can get a full twelve months' use out of a pair before replacing, but who cares---the only thing more important than steering & stopping a vehicle is being able to see clearly where you're going in said vehicle. :)
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    From AudiEnthusiasts.com
    After-wipe of windscreen wipers when windscreen washer has been used
    [09 – Cent. Elect.]
    [Coding - 07] -> [Dropdown] -> "x -- 8K1 955 119 -- WWS xxxx" ->
    [Long Coding Helper] -> Byte 1 Bit 3 - 1= Active 0 = Disabled
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Three Rings infinitereality's Avatar
    Jul 05 2017
    Superlite Coupe (SLC) & CRF50
    Louisiana
    This always has annoyed me as well. I don't live in the snow, but do park in gravel at work so I have to use the washer fluid to clean windshield every so often and that courtsy wipe always mkes it worse than if it didn't do it.
    Can't believe I didn't come across how to turn it off via VCD on the main thread, thanks gk1!
    2018 Camaro ZL1 - Black
    - OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
    - RotoFab, Forgestar CF5V ZLE offsets, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
    - Carbon Fiber: Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
    2019 Superlite Coupe: SLC IR/8 - Grigio Telesto
    - 525HP Crate LS3 & Graziano Transaxle
    - 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
    Jan 11 2019
    Calgary
    Thanks guys, I'll order some new ones and see if that helps. It's annoying because it'll get nice and clean, then the wipers just smear it again.
    As for vcds, I don't know any one local who does it, and haven't looked into what I'd need to do it myself. Something to research this weekend maybe.
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    I do understand what the OP is saying - when you are driving on sloppy roads, depending on the temperature (probably pretty cold in Canada), after you clean the windshield, mess from the road can get on your windshield before the delayed wipe, causing streaking. Glad there are options for the OP to turn it off.
    Wipers - I have found the AUdi OEM wipers to be the best (not sure the actual manufacturer). For $50, I've found these last longer in New England Winters/Rainy Springs, compared to others that don't last nearly as long.
