Results 1 to 21 of 21
    Oct 20 2019
    OKC
    $1,300 for wheel bearing
    I purchased a 2015 A6 last month and took it in today to get the oil changed, battery checked, and wheel bearings. Long story short I got quoted $500
    to replace the battery and $1,300 for left front wheel bearing. I had them replace the battery, but the quote for the wheel bearing sounds high. Is this the normal pricing, this was my first experience with servicing an Audi. I’m coming from an 08 GS350, and never took it to the shop. Also, the SA contacted Fidelity for a warranty claim and it was denied.
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 01 2014
    Las Vegas, Nv
    Quote Originally Posted by TexasMyke View Post
    Take it to Firestone or something like that I had one go bad years ago it cost me like $175, I'd tell that dealer to shove it.
    Sent from my SM-G955U using Tapatalk
    AKA: Yoshi123
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    At an Audi dealership $800 - $1000 is not out of the ordinary for a wheel bearing and take your car to Batteries Plus for the battery. Find a good independent repair shop that specializes in European cars. If you did not take note of the maintenance cost difference between your Japanese and your German car, you are in for a rude awakening.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Oct 20 2019
    OKC
    I thought the battery had to be programmed to the car so that it wouldn’t degrade quicker. That is the only reason I let them do it. Status report said the battery tested at 428 vs 520 cold cranking amps. Battery, oil change, and 85,000 mile service was a little less than $800. I relied heavily on the ClubLexus forum to diagnose and repair my car. I plan to do the same using this forum. I’ll buy the bearing and have some Indy shop install or I’ll do it myself
    Oct 21 2019
    Salt Lake City / Utah
    Here are some links I have to help your Forum search on installing bearings yourself :
    * FRONT Wheel hub & bearing -
    https://www.audizine.com/forum/showt...?highlight=DIY
    https://www.youtube.com/watch?v=6pnR...&index=17&t=0s
    * REAR Wheel hub & Bearing - https://www.audiworld.com/how-tos/a/...earings-421777
    2015 Audi A3, 2015 Audi Q3, 2013 Audi A5 Cab.
    1976 Toyota LandCruiser
    Junior Member Two Rings
    Nov 10 2018
    2014 Audi Q5 TDI
    Wausau, WI
    Over this past year had all 4 wheel bearings replaced, 2 at a time, and each time it cost that. Went to a local alignment specialist, not Audi. My only oil change at the dealership cost me 300 dollars, can’t imagine what this work would have cost.
    Established Member Two Rings Fast001's Avatar
    Oct 12 2014
    Toronto, ON
    Take it to an indi shop and save yourself a $1000... Had 3 already replaced on mine, at $300CAD per corner with a *** bearings.
    - - - Updated - - -
    Not sure why the ***, but replaced mine with F.A.G. bearings.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    $500 to replace a $200 battery????????
    I know there is programming involved but there should not be $300 for labor to replace the battery and program it. Takes less than 30 minutes to change a battery and if you have VCDS you can program the battery yourself.
    Oct 20 2019
    OKC
    I won’t be going back for any work unless I have too. Any recommendations for a good shop in Oklahoma City? I just moved here.
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    Quote Originally Posted by Fast001 View Post
    - - - Updated - - -
    Where'd you get yours done in Toronto? In case I ever have to do mine...
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    Quote Originally Posted by Valpo A7 View Post
    Is this programming essential? What does one do if one must replace the battery, doesn't want to go to the dealer, and doesn't have VCDS?
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Oct 20 2019
    OKC
    The SA said the battery would degrade faster if it wasn’t programmed to the car. You could change the battery and it would still work, but the cars computer would still be set to the prior battery’s levels. Really just unnecessary to have a battery programmed to the car.
    Oct 21 2019
    Question : If one replaces the OE battery with a new OE one with same features ( CCA, Mfg., Model, etc ), is VCDS needed ?
    BTW : my Indy charges $ 85 USD for oil service, plus tax -- not much more than my retail cost of the oil and filter ! And service includes the other checks for the Standard service
    Oct 21 2019
    I see that Audionlineparts.com charges $ 300 for the hub & bearing assembly ( 8K0-407-607 ). Sound like a DIY candidate to me.
    Oct 12 2014
    Toronto, ON
    Got my own bearings off eBay and paid $150 for install at Eco-Wagens in Newmarket.
    - - - Updated - - -
    Quote Originally Posted by Vinng86 View Post
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Payed 240 for a front wheel bearing labor only. I think part was also another 90$ for f.a.g.
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    If you have (or buy) VCDS, there's a youtube video on how to code your new battery in the ECU. IMO that's a much better use of $150-300 depending on which setup you get (assuming you don't already have it).
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Mar 21 2016
    Columbia South Carolina
    $400 for a rear, parts and labor at an indy
    Established Member Two Rings DeRico's Avatar
    Aug 10 2012
    1993 Toyota Chaser, 2018 VW Atlas
    San Antonio, TX
    $1,100 parts, labor and install for all 4 at Brink
    '13 C7 A6 Quartz Gray
    >APR Intercooler
    >Michelin PS4
    Oct 20 2019
    OKC
    I plan on hopefully getting it done while I’m back in Houston/Katy before thanksgiving. I just need to find a decent shop.
    May 21 2007
    Florida
    $350-400 sounds more accurate for a battery. and wheel bearing should be more in the $800 range. unless their labor rate is crazy high. i know west palm beach audi's labor rate is over $300/hr which is insanity. but that area has lots of $$$. normal audi labor rate is typically is the $150/hr range.
