Just got cold here (-15C) and had a CEL pop up a day after our cold snap. I scanned the codes, getting random intermittent misfires on both engine banks (no additional codes). Spark plugs and coil packs were replaced ~35,000km ago and a CC done in between then and now. Voltage is below 13.7V on a few of the misfires which is sparking my question; pun intended. I know when the cold comes, weak batteries tend to expose themselves and I don't know the last time the battery was replaced (at very minimum 6-7 years ago). I know I should check the battery and alternator voltage but don't have access to a multimeter at the moment. Any thoughts?
__________________________________________________ ________________________
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
Part No SW: 8E1 910 560 J HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0010
Revision: 57H15--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 22103 444 53784
VCID: 2D07094D111CC92F521-8078
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 118738 km
Time Indication: 0
Freeze Frame:
RPM: 1433 /min
Load: 58.0 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 12.0°C
Absolute Pres.: 930.0 mbar
Voltage: 13.208 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 118738 km
Time Indication: 0
Freeze Frame:
RPM: 1433 /min
Load: 58.0 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 12.0°C
Voltage: 13.208 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 119150 km
Time Indication: 0
Freeze Frame:
RPM: 1091 /min
Load: 70.2 %
Speed: 14.0 km/h
Temperature: 48.0°C
Temperature: 26.0°C
Absolute Pres.: 950.0 mbar
Voltage: 13.716 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 119150 km
Time Indication: 0
Freeze Frame:
RPM: 1091 /min
Load: 70.2 %
Speed: 14.0 km/h
Temperature: 48.0°C
Temperature: 26.0°C
Voltage: 13.716 V
000776 - Cylinder 8
P0308 - 008 - Misfire Detected
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 119216 km
Time Indication: 0
Freeze Frame:
RPM: 1082 /min
Load: 54.1 %
Speed: 14.0 km/h
Temperature: 69.0°C
Temperature: 32.0°C
Absolute Pres.: 940.0 mbar
Voltage: 13.589 V
