Results 1 to 13 of 13
    Veteran Member Three Rings mark_ma's Avatar
    Feb 25 2015
    Denver/Colorado
    LED fog lights, remove error bulb out using VCDS
    If you are like me and installed LED for the fog lights and you get the error bulb out on your dash. There are two mechanical ways on fixing this. 1) buy a resistor and hope it works. 2) buy the correct over price bulb that work right out of the box. The third way is using VCDS. Going this route get a good LED from amazon --link--> Amazon LED Fog lights ( side note: this is what I have on the q7 and the s4, these are bright and do a great job!) and make use of VCDS and get your money’s worth from your vagcom cable. Now, before I go any further about coding it out with VCDS. Down the road when one or both LED fog light do go out. It will not show on the dash that a light is out because what VCDS does is put a patch on the fog lights to bypass the error, but there is still current being sent to the fog lights. Just be aware if you are driving at night and notice a fog light is out. But with LED they last longer than halogen/HID so it’s nothing to worry about in the near future
    So let’s begin. This was done on a 2013 Q7 TDI
    Pull up VCDS
    Go to “Select Control Module”
    Select “09-Cent.Elect.”
    Select “Security Access–16”
    In the blank space you want to type in “12151“ and select “Do It!” this number shows up in the bubble as shown and also can be found if you go to ross tech wiki under security access. --link-->wiki ross-tech
    To my understanding this is giving permission for VCDS to get access for you do some changes. By typing this nothing is being changed. All it does is open the door for you to go in and change stuff around. If you don’t do this process in security access first the next steps won’t work
    Now to go “Adaptations-10”
    In the drop down menu go select “Front Fog Lights”
    This is what shows up now. In the box that says New Value. You will inter the number “1 “. In the bubble as shown below says [0 = front fog lights installed] and [1 = front fog lights NOT installed (fault code suppressed)] by default it should have the value of “0” since there are fog lights installed and because of the LED I’m using it generates a fault code. As the bubble says if you put the value of “1” it suppresses the fault code. As I mention before, it still will send current to the fog lights
    Click “test”
    And finally click “Yes”. All done!
    Now clear the fault codes by going to “Fault Codes-2”
    I turned the car off from aux mode and started it up again and I didn’t get the loud beepy sounds it gave me when I did have the error bulb on the dash. Have had no problems since
    Le build thread of mark_ma,
    Instagram: @mark_b6s4, Youtube: markb6s4
    4 wheels, 8 pistons, two mufflers , ultra light weight seat warmers, see through windows, carbon fiber turn signals, wireless key fob, photon reflecting side mirrors
    Mar 28 2009
    Minneapolis, MN
    This is all great info.
    In my 2012 Q7, I went with the iJDMtoy 3000K LED foglight and got bulb out errors. I added an H11 load resistor* and that got rid of the error message.
    *This isn't the exact one I purchased but is very similar. The one I bought is no longer available on Amazon.
    Active Member Two Rings chrisfast's Avatar
    Nov 06 2014
    Colorado
    Great write up. Do you, or anybody on here, happen to know if we can code the vehicle to use the fog lights as cornering lights when the headlights are on? Thanks again fire the write up.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by chrisfast View Post
    I believe that you can do that through Carista so I'd guess that you can also do it through VSCD. check out Ross techs site under our platform to see if there's a wiki available to do that. I'd be surprised if one didn't exist for it.
    Sent from my SM-N950U using Tapatalk
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Nov 06 2014
    Colorado
    Quote Originally Posted by blackfunk View Post
    Will do. Thank you!
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    This worked out great!!
    Thank You!!!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Established Member Two Rings RAUDIRS6's Avatar
    Dec 02 2013
    18 RS7P, 14 Q7 TDI
    Lusby, MD
    Taking this out of the grave to say thank you.
    2018 RS7 Performance (Nardo)(DS1 Mod Stage 2, JHM TCU, ECS Intake/Inlets, CWA-100, ARM DP w/ HF Cats, ECS 2.75" Valved Exhaust, 40T E-Sensor w/Bypass & Lines, 034M HPFP, Forge BOVs, JHM T&D Inserts, 034M Tunnel Brace)
    2014 Q7 TDI (RSNav)
    2004 S4 Avant 6MT
    2003 RS6 (6MT Conversion Project)
    2002 Passat Wagon
    1998 Passat Sedan ($1250 Budget Build Project)
    2000 New Beetle
    Established Member Two Rings studioRS's Avatar
    Jul 19 2013
    So Lake Tahoe
    @dropshadow - Bought a set of these H11 load resistors you linked to, thanks!
    Confirming that they work and don't show the bulb out error using deAutoLED dual color LEDs in 2015 Q7 3.0T.
    2016 Audi SQ5 Glacier White Metallic, technology & black optic packages
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by studioRS View Post
    Only caveat is that these get hot when in use.
    Jul 19 2013
    So Lake Tahoe
    Yup, these get really HOT. Glad I tested them first, plugged in and outside in the open!
    Solution for placement with maximum cold airflow over the resistors.
    This is on a 2015 Q7 with S-line bumpers.
    - Unscrew fog lights from mounting points.
    - Plug everything in (make sure to have wiring hooked up correctly (Yellow Pos.(+) and Brown Neg. (–) )
    - Snake the resistors and wiring through the inboard plastic deflectors (towards the center), into the cold air intake space.
    This makes each Resistor and wiring hang in open, cold air, not touching anything. I used one Zip-Tie to fix the wiring to this plastic. I'll snap off a photo with the grilles off.
    Jul 19 2013
    So Lake Tahoe
    Curious if anyone has tackled this yet on a Q7 with a solution? (sorta on track with the OG thread VCDS Fog Light fix...)
    Enable Fog lights on with High Beams.
    This below worked like a top on my 2016 SQ5 and ex-B8 A4 Avant Sport.
    VCDS
    Enable Independent Fogs control with high beams
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0*
    Checked on my brother's 2015 Q7, no Long coding helper in Coding-07. Not sure how to proceed.
    Mar 28 2009
    Minneapolis, MN
    VCDS
    I know I had this working on my 2012 4L, but it may have been via the Carista app. I did some coding with VCDS and some with Carista on that car.
    Established Member Two Rings GeriatricGinger's Avatar
    Apr 21 2014
    10 A4, 16 A4, 09 GLI, 11 Tiguan
    Virginia
    Out of the depths, I did this a year ago when I put in the LED fog lights..
    However, even with this set to zero, I still get foglight out warnings and buzzers. I revisited it today, and it still shows zero (not installed.)
    I dont know.. 2013 4L Q7 3.0T
    Audi: 2010 A4Q - 2.0T, 2013 Q7 Prestige S-Line - 3.0T Stg2+, custom air ride, JHM/Magnaflow/540Autosport, 2016 A4 2.0T S-Line CVT - Koni, H&R, 19" Petals, Black Optiks
    VW: 2010 CC Sport 2.0T - Stg2 Unitronic, BC Racing, 20" Atlas, 2" TBE, 2011 Tiguan S 2.0T - Racelands, 20" Atlas, tint
