Results 1 to 26 of 26
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    MirrorTap install DIY instructions
    Step1: Pull the longer cover off (the one that touches the headliner). Do this by pulling down on the skinny side and then there are two tabs (one each side toward the top) that hold this cover to the other plastic cover. Just press in on the long cover where the tabs are to release.
    Step 2: Put red lead into the top left hole (where the red with blue stripe wire is), and black lead into the next hole to the right (where the brown wire is)
    Step 3: Test! Plug your radar detector in, turn car on.
    Step 4: drill small hole in the side of the plastic cover where the two covers meet
    Step 5: Reassemble in reverse order.
    Step 6: Successfully avoid interactions with the police.
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Established Member Two Rings OCTA1NE's Avatar
    Oct 16 2018
    E46 M3 CSL race car, E70 BMW X5 40D.
    Sydney/Australia
    Fark I wish I lived in US of A....that's illegal in Australia....
    Jan 03 2019
    Quote Originally Posted by OCTA1NE View Post
    My previous radar detector clearly paid for itself. However, there are so many false alarms these days due to blind spot monitoring systems, that I’m not sure how effective this tool today.
    Feb 06 2015
    I have a 15 year old valentine 1 that resets itself but still this works to this day. They work just need to look at the band. Was looking into r7 but might just get another v1.
    Jan 17 2018
    1995 Pontiac TransAm Convertible, 2015 VW GTI, 2023 Genesis GV70
    Round Rock (Austin), Texas
    Quote Originally Posted by mbar View Post
    Around here, cops only use Laser and Ka band. I disable X and K (which blind spot systems generate) bands.
    Senior Member Two Rings RSKYBET's Avatar
    Jan 16 2018
    Midwest
    I'm using a Mirror Tap with my Uniden R3, but I didn't drill a hole in the cover. The lead was long enough to route out of the cover up near the slender portion. I'm not using a Blend Mount, though. Will try to post a picture later.
    2017 Audi RS3 1 of 244 (250) and 1 of 33 in Mythos Black
    @surprs3
    Senior Member Two Rings Potshot's Avatar
    Oct 18 2019
    New albany, in
    Thanks for this! What mirror tap kit did you use? I read somewhere that one of them has too short of a lead.
    Sent from my SM-G973U using Audizine mobile app
    2018 RS3 Black
    Nov 01 2019
    Elk Grove, CA
    I just installed my Uniden R3 in my 19 RS3 and used this mirror tap:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I had a mirror tap laying around and the probes were too small/short. That one worked fine, using the larger connectors.
    Sep 22 2008
    Minnesnowta (Roch)
    Quote Originally Posted by Potshot View Post
    Mt-1015 - go to mirrortap.com and enter in the info they ask on the first page and it will bring you to the correct kit to buy.
    Jun 29 2018
    Ellicott City/MD
    Quote Originally Posted by unixadm View Post
    What's the thing with 4 buttons above your mirror?
    2019 RS3 | Iroz 850S | DS1 ECU | Unitronic Stage 3 TCU | Redline 5" Ti Intake | STM FMIC | Redline Ti Turboback | ECE Red Dogbone/Mounts | Tyrolsport Deadset Kit | ECS Rear Subframe/Diff Poly Bushings | Unibrace XBQ | Neuspeed Front/Rear Swaybar/Endlinks | KW V3 | Signature Forged SV701/SV304S
    Nov 01 2019
    Elk Grove, CA
    Quote Originally Posted by kisho View Post
    A garage door opener. About $16 on Amazon. I bought some thin heavy duty adhesive backed hook and loop to affix it. Not my ideal solution, but it works perfectly.
    Oct 18 2019
    New albany, in
    Flynnr, is this a 2019? My 2018 doesnt look like that. There other picture in this thread is what mine looks like. Just curious if the difference is by years?
    2018 RS3 Black
    Sep 22 2008
    Minnesnowta (Roch)
    Yeah 2019 for me
    Oct 17 2014
    NorCal
    Dave what mount are you using? PS I pick up my RS3 on Monday through Cain! Thanks, a bit of emailing back and forth but he ended up with the best deal and being the easiest to deal with.
    2019 RS3
    2014 S4 P+
    Nov 01 2019
    Elk Grove, CA
    Quote Originally Posted by Evan2 View Post
    Congrats! I'm using an adhesive mount that just sticks to the windshield. It's made for Uniden detectors. I picked up a couple a number of years ago but never used them. When I was test fitting the R3, I grabbed one of the mounts I had and was able to position the detector as shown in the picture. I liked it, versus my typically Blendmount approach below the mirror. There's just enough room up there so that it doesn't interfere with the passenger sun visor.
    Oct 17 2014
    NorCal
    Nice I will have to look that up, going on base every day I am hoping the gate guards dont see it as you cannot have them on base. I like how yours is tucked away a bit.
    2019 RS3
    2014 S4 P+
    Senior Member Three Rings mezgermischief's Avatar
    Jul 13 2015
    997.2 GT3RS
    Thank you so much!! Just for clarification to help others. This is the install process for vehicles without adaptive cruise control and all those front safety features. All the past install guides have been for cars with ACC (they have a different mirror) so I am extremely grateful to be provided install instructions for vehicles without this! Cheers
    Oct 18 2019
    New albany, in
    Well that is good to know. It sounds like it didn't change from year to year, but is more likely what iStig just posted that cars with ACC have a different mirror. I wonder if the wire tap is the same across the ACC non ACC models.
    2018 RS3 Black
    Oct 17 2014
    NorCal
    check the post that is near the top, I just posted in it. DAP is a tiny bit different but similar.
    2019 RS3
    2014 S4 P+
    Senior Member Three Rings Phayl's Avatar
    Dec 12 2017
    Dallas, TX
    Quote Originally Posted by testwerke View Post
    Attachment 202805
    Just tried this myself with the Mirrortap MTX-2015 and a Blackvue DR750X-2ch dashcam but can’t get it to power on. I verified voltage with my Fluke multimeter and I see right under 12v. The cigarette outlet power adapter powers on the dashcam no problem, and I verified the voltage is also right under 12v with that adapter. I’m so confused why this isn’t working.
    EDIT: according to blackvue, they changed their male DC plug dimensions on their X series, so the mirrortap is useless.
    https://blackvue.com/x-series-built-...e-accessories/
    If your leads touch, they will break the fuse. This worked fine for me, just make sure they get in there deep enough. May have to wrap non-contact with electrical tape so it doesn't short.
    Senior Member Two Rings WmRS3's Avatar
    Dec 13 2019
    Audi RS3, Audi S8, Ford Raptor, Volvo S60R
    MA
    I installed mine 8 days ago parked the car went to drive it today totally dead battery. The radar detector is not powered on unless the ignition is on has anybody else had an issue with this? The car is not driven very much but the battery was totally drained.
    Junior Member One Ring
    Feb 18 2020
    New York
    Many thanks for this OP. Installed the blendmount and mirrortap with ease for my Uniden R7. Verified the ground and 12v with a multimeter. Also didn't have to drill a hole. Ran the wire over the top.
    @WmRS3 I'll keep an eye on it to see if there is any battery drainage this week since it'll be in the garage. So far the voltage had been constant (12.4) for the past day.
    Sent from my Pixel 2 XL using Audizine Forum mobile app
    Dec 13 2019
    MA
    Quote Originally Posted by MistahMahk View Post
    I found a bad ground on the cam cover from doing coil n plug swap so that may of been it.
    Mar 11 2021
    CO
    Thanks! The instructions were very helpful. Worked for my 2015 Audi S4.
    Bought following mount and mirror tap for my og escort passport 8500:
    Mount: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Mirrortap kit: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Veteran Member Four Rings 2380S4's Avatar
    Jul 16 2008
    2001 S4 Avant, 07 DTM S4, 15 328XI & 90 Turbo Grand Prix
    Living The Dream!!!
    From this!!
    To this!!
    Much improved and it took 10 mins to do. Do not know why I waited so long.
    Current: 2018 RS3 Audi Exclusive Navarra Blue Stage 2 ECU 93 & TCU Unitronic, Intake, Inlet, Intercooler all Unitronic, Downpipes APR, ECE dogbone, KW HAS, APR coils, 7437-9 plugs, Eurocode Sway Bars & End Links.
    2001 S4 Avant Brilliant Black STG 1, ST Coilovers, AWE Twin 2, XS Power DP's, Neespeed Rear Sway Bar, 034 Adjustable End Links, 034 TBB & Bi-Pipes
    Past: 2007 S4 DTM
    Past: 2001 S4 10 years
    Past: 2013 A5
    Garage: 1990 Pontiac Turbo Grand Prix 1 of 3400 made in 89&90
    Dec 16 2020
    NY, NJ
    Quote Originally Posted by 2380S4 View Post
    From this!!
    To this!!
    How did you disconnect the harness??? It seems to be so delicate and the wires are small. Is there a clip that needs to be depressed or something? I have the Blendmount, and a new detector on the way.. Would love to get this installed. thx!
