Results 1 to 17 of 17
    Sep 12 2017
    Virginia Beach/VA
    A Marriage of Two Engines...4.2L RS4 Components & S4 Foundation, Wishful Thinking???
    I'll start with a few disclaimers:
    1. I have No Idea which thread this belongs in as this is a forth coming DIY pending any information you all may offer
    2. I have these parts already BEFORE you ask why don't I do X or Y
    3. It's more a genuine interest in the potential challenge
    That said...I have a blown RS4 engine that grenaded two cylinders and the block has significant damage in those cylinders. As such, I have a S4 complete engine but needs some cylinder head work. Naturally, considering that the blocks are similar, I am pretty much considering transferring the good components that are left from the RS4 engine (crankshaft, rods, pistons, etc) onto the S4 block. I have already torn down the RS4 engine and know that 2 pistons were damaged so I am sourcing those now (and also considering a new set I found overseas). I've noticed a few differences in some of the fasteners (cylinder head bolts) and was just wondering whether or not this fateful marriage may/may not work.
    From initial research, many components are similar between the two block with much of the difference in the RS4 being forged internals, differences in the cams and cylinder heads, and many flow control components.
    I have experience tearing engines down but not totally familiar with Audis. I'm hoping that some of you with more Audi experience with the 4.2L v8 can chime in and offer some ideas or considerations when comparing the 2 blocks along with potential haphazard.
    Nov 12 2015
    Oregon
    I hate to be the bearer of bad news, but I don't think it will work out. The only thing the two engines share in common are the looks and the displacement. Just about everything else is different between the two. They take different head gaskets, different timing components, different fuel system, different rods, different camshafts, etc... I'm no expert, and I would absolutely love to see this work out. I just don't know if it is possible without a bunch of custom work. If that's what you're into, then absolutely give it a shot.
    Subbed for content
    Sent from my SM-N920V using Tapatalk
    My build log
    Sep 12 2017
    Virginia Beach/VA
    Quote Originally Posted by VinnysS4 View Post
    Subbed for content
    I understand the things mentioned, but in consideration what are your opinions of the following:
    1. S4 block mated to RS4 heads, crank, rods, and pistons - Unless the cylinder chambers are different in length, this should address some of whats mentioned. Would have to see how the timing components match up of course. Cooling may be the main thing with different flow ports and channels.
    2. Fuel delivery can be addressed later, have the parts to swap. Just have to get the low and high pressure RS4 pumps.
    3. Between myself and my father, most of the custom work (if necessary) can be done. Plus have an additional engineer/gearhead offering assistance. Going to take pics along the way in the event everything works out. The only issue may be with the proper amount of tuning. Just realized I may need to consider a new MAF and throttle body to handle the airflow.
    Nov 12 2015
    Oregon
    when I was rebuilding my S4 I was sent RS4 head gaskets. I compared the two and the oil and coolant ports did not line up. I don't remember if the head bolt placement was the same either.
    I would suggest getting your hands on both car's head gaskets and seeing if you can make it work
    My build log
    Sep 12 2017
    Virginia Beach/VA
    Totally concur. Being that I have RS4 heads, the only issue is aligning the gasket to the block itself and checking ports to see if the gasket covers anything. If there are any blockage issues that can't be addressed, then I may just move the hardware (valves, springs, etc) from the RS4 head to the S4 head. It would essentially give me the same thing in theory.
    Concerning head bolts, alignment can be checked as well using the head gasket. The 1 thing boggling my mind is the head bolts themselves. I have noticed that OEM RS4 head bolts have been significantly lower in price than S4 head bolts. Apples to Apples was an avg of $36 for the RS4 for a set of 10 vs $94 for S4....with $43 being an aftermarket set of bolts for the S4. Any ideas there?
    Nov 03 2011
    All Over!
    I thought the RS4 valves were different to those of the S4. I might be wrong though.
    1986 Type 85 Audi 90 quattro
    Sep 12 2017
    Virginia Beach/VA
    You are correct, they are a bit different but nothing that can't be worked around.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    As said above, apart from sharing the manufacturer name and similar displacement these are two different engines. After a quick google:
    Quote Originally Posted by dparm View Post
    The 4.2L 40V V8 has many variants. They are the same basic engine but that doesn't mean they're completely interchangeable. Below is data from ETKA.
    BBK: Audi B6 S4, Audi B7 S4
    BHF: Audi B6 S4, Audi B7 S4
    BAT: Audi A6 (04/04-05/06)
    BFM: Audi A8 (11/02-05/06)
    BGJ: Volkswagen Phaeton (05/03-07/03)
    BGH: Volkswagen Phaeton (08/03-05/10)
    AHK: Audi C4 S6 Plus (06/96-10/97)
    AQJ: Audi C5 S6 (09/99-05/01)
    AHC: Audi D2 S8 (09/96-12/98)
    AKH: Audi D2 S8 (08/97-12/98)
    AQH: Audi D2 S8 (05/99-02/01)
    AVP: Audi D2 S8 (09/00-09/02)
    BCS: Audi D2 S8 (09/00-02/01, Japan)
    AYS: Audi D2 S8 (02/01-09/02, Japan)
    The 4.2L 32V V8 FSI, which is the RS4 motor, was used on many Audis/VWs including the A8, Q7, Touareg, R8, etc. That motor is completely different from ours.
    There was also the older 4.2L 32V V8 non-FSI from the D2 A8, C5 A6, C4 S6, and C4 S4.
    In regards to your valve exchange endeavor, what do you wish to achieve by getting bns valves to fit the bhf? Don't get me wrong, I like machining custom parts and making things work. But the desired end result is questionable. If it is for the sake of making Frankensteins engine, by all means, go for it and post pics! If you only wish to have a working performance engine you will be better off with upgrading the BHF with stronger internals, fixing the timing components (as you already have a BNS, the timing guides are interchangeable) and fitting a blower. The BNS is shot if the block is damaged. AluSil is not forgiving for repairs.
    Quote Originally Posted by Manystylze View Post
    Apart from 8 valves missing and requiring custom valve guides for the different clearance? The S4 BHF engine is 40-valve EFI, the RS4 BNS engine is 32-valve DI
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Something else to bear in mind is that the timing sprockets throughout the engine may be different.... more/less teeth. Should look into that.
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Jun 09 2014
    BMW E28 with S54 Swap, rack and pinion conversion, vacuum brake conversion
    Jacksonville,FL Lincolnton,GA
    Quote Originally Posted by roboto_1337 View Post
    On the BNS the idler gears have 38 and 19 teeth. The camshaft sprockets have 25 teeth. The BHF has 30 teeth on the camshaft sprocket.
    Sep 12 2017
    Virginia Beach/VA
    Quote Originally Posted by ottocycle View Post
    Good information to note. Thanks
    Sep 12 2017
    Virginia Beach/VA
    Quote Originally Posted by ven0m View Post
    Indeed a Frankenstein of sorts. The difference between the heads should only be an issue pending cooling channels between the blocks. My comment that "nothing I can't work around" was only pending there is too much an issue utilizing the RS4 heads and possibly interchanging hardware. I will definitely post pics as I go along and record/describe the journey. The RS4 block was pretty much shot after the damage to the 2 cylinders (one maybe salvageable by sleeving but the other too far gone). May just have to source another or Q7 block...was just hoping to see if the challenge of utilizing a block I already have would be beneficial, plus I like the challenge.
    Jul 05 2016
    Ontario, Canada
    A Q7 short block might be the best case. I’m not sure of the differences there. But more likely to have abstained abuse
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    RS4 pistons are DI-specific and are relieved for a 4 valve combustion chamber. There could be valve clearance and misfires if you do not use the RS4 pistons to match the cylinder head.
    2008 Audi RS4 Ti Mugello Blue / Ebony
    2004 Audi S4 6MT Saloon Brilliant Black / Ebony
    2012 Lexus CT200h
    Sep 12 2017
    Virginia Beach/VA
    You're correct. The Q7 and RS4 are supposed to be the same exact engine and block with differences in the heads, intake, etc. Keeping my eye out but at the same time, curious to see if I can make magic with parts on hand. It's the Engineer Mechanic in me
    Sep 12 2017
    Virginia Beach/VA
    Quote Originally Posted by S4Bennett View Post
    I have 6 of 8, two of mine grenaded when the flap pieces fell into the cylinders. I am sourcing 2, but hoping to find a full set to ensure they are matching, balanced, etc
    SO the RS4 heads and parts I have are from the same engine/vehicle.
    Sep 12 2017
    Virginia Beach/VA
    Actually revisiting this idea. Found a Q7 block at a price I can't refuse. May see about grabbing it. Looking through some more articles online I see that my biggest milestones will be cooling paths, timing gear, and software.
