Results 1 to 22 of 22
    Established Member Two Rings VPRS7's Avatar
    Nov 01 2014
    100,000 km & Still Running Strong ('14 RS7)
    Just rolled over 100,000 km this past weekend. Car has treated me very well over the years. The only repairs have been a replaced thermostat and O2 sensor, both around 90,000 km. My DSC shows a fault code, but tells me it is fine to keep on driving and it hasn't been an issue and there appear to be no leaks from the shocks or hydraulic lines.
    Starting to think about a new car, likely something smaller, but I will never be able to give up this kind of power!
    2014 Audi RS7: Daytona Gray / Unitronic Stage 1+ Tune / 21" Corse Werks Agio Monoblock w Michelin PSS / DRC / KW H.A.S. / Eurocode Sways / AWE S-Flo Intake / Sport Exhaust / Carbon Inlay / B&O / VAG mods
    Former: 2012 C63 AMG Coupe, 2012 M3, 2008 M3 Sedan, 2004 M3, 1998 M3 (track-prep), 1998 M3, 1991 M5....
    Aug 08 2018
    New Hampshire
    DRC fault?
    I learned to hate that light on my RS7 with DRC.
    Jan 17 2017
    How long have you had the car? Have you done anything to the oil screen/turbos?
    Established Member Two Rings LQQKOUT's Avatar
    Oct 09 2019
    Omaha, NE
    Mine has just over 106k Miles, so about 171k Km.
    Sent from my LG-G710 using Audizine mobile app
    Mar 12 2018
    Toronto, ON, Canada
    This is reassuring (I think)
    I'm at 51kms but fairly heavily modded on my 2017 RS7. I'd love for it to stick around until 171kms but I feel like something bad will go long before then.
    Thinking about grabbing a winter daily as to not daily the RS during the winter months and save some km's on her. But the wife will likely kill me in my sleep if I get another car haha. Apparently 1 person doesn't "need" 3 cars, but that seems like hogwash to me!!
    Sent from my SM-G960W using Tapatalk
    2017 RS7 Nardo grey w/ Black Optics | Carbon | Miltek Non-res Catback | SRM intake (long) | Lowering Links + VAGCOM | Flush fit ECS Spacers | Blacked Out Heads/Tails/emblems/roof wrap
    Prior:
    2014 nicely built S5 Technik
    Oct 09 2019
    Omaha, NE
    Mine has been running an APR Stage 1 tune for the last 50k miles.
    Mar 12 2018
    Toronto, ON, Canada
    Quote Originally Posted by LQQKOUT View Post
    Phew, also good to know thanks
    Prior:
    Nov 01 2014
    Yes typo, but I don’t see any issues
    Quote Originally Posted by kebabman View Post
    DRC fault?
    Nov 01 2014
    Quote Originally Posted by NardoRS7 View Post
    Bought it new 5 yrs ago. Nothing yet, what do you recommend? I am due for a service right now
    Any input is appreciated as I intend to keep this car for a couple more years
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by VPRS7 View Post
    You are at the threshhold mileage where folks have been seeing turbo failures secondary to the oil screen that feeds the turbo lines becoming clogged. If you plan on holding on to the car, I would highly suggest swapping out to the latest part numbers of the turbo oil screen and the oil separator (PCV). Essentially the same exact labor, as you have to remove the PCV in order to get to the turbo oil screen. Labor is difficult, (about 10 to 12 hours), as the entire front clip and charge air cooler housing need to be removed in order to get to these parts.
    Recommend getting new parts online and finding a trusted indy shop to do it. You may also want to get all new turbo lines/gaskets, as many folks have been finding dry rot at the gaskets due to high heat levels. Also minimal additional labor, since they'll be fully exposed when getting to the other parts. If you are mechanically inclined, WhiteWhiteS7's thread on this forum is an excellent DIY.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Nov 01 2014
    Quote Originally Posted by OlyS6 View Post
    Been away for quite a while, but just had full service done and inspection of the turbos. All good. That being said, roughly how much are the above-mentioned parts? I assume not much in comparison to the 10 to 12 hrs labour. I am likely going to keep the car for a couple more years (say another 40 to 50,000 km) for a total of 150K or ~95K miles.
    Aug 13 2018
    2016 S6
    Florida
    That's great to hear all is good with the turbos. If you don't mind me asking, how much did you pay to get them inspected? The extended warranty on mine runs out soon, and I've been going back and forth with selling it, extending the warranty, or tuning it and hoping for the best!
    2019 Raptor
    2016 S6
    2015 RS7 - Sold
    Nov 01 2014
    Quote Originally Posted by Wilbur_RS7 View Post
    My non-dealer mechanic inspected from the inlet side for no charge.
    Registered Member One Ring 15RS7's Avatar
    Sep 20 2018
    Vancouver,BC
    @96,000KM. No engine issues after a fuel pump replacement at around 20,000KM.
    If it helps, that issue was diagnosed after engine would momentarily cut out at high RPM's.
    Stock turbos, regular service intervals. Always make sure I take the long way home so oil gets up to at least 90 degree Celsius.....and because its more fun that way.
    Power train seems to have held up well considering the amount of HP these cars make. only major fault recently has been leaking front DRC struts which Audi Canada offered to pay 70% of costs out of good will....and me nagging.
    Junior Member Two Rings
    Feb 05 2017
    Florida
    Just rolling through 200k kilometers on my 16 S6. Good to see others doing some miles as well. Do we have a mileage thread for these puppies?
    Sent from my LM-G850 using Audizine mobile app
    Jan 09 2013
    UK
    Just clicked over 90k miles so just under 150k km, 2015 non performance RS7, APR Stage 1 for the last 40k miles, just had to replace the rear sports diff but then running 1100+NM of torque through it, it’s the first repair that’s had to be done of any kind in 5 years so I can’t complain
    Jan 30 2007
    CLS63 AMG
    Bottom of the mountain
    100,000km is hardly anything.
    I recently sold my 2013 S7 at 85k miles, and things were starting to go wrong. These SOB's are fragile.
    Nov 01 2014
    Can I drive with PCV leak?
    Well the troubles begin.... Now at 110K and I am having the whistling PCV issue. Started yesterday and what a whine it is. At first I thought it was the turbo bearings, but when I got home I found this service bulletin: https://testing-public.carmd.com/Tsb...107335/A171562 There is a great video link in the bulletin which is definitely the sound I have [URL="https://audi-external.kzoplatform.com/swf/player/311"].
    Car is well out of warranty and it looks like there is about a full day of labour involved. I am at my cottage (300km) from my local guy, but there is a dealer 30km away, but I have never been a fan of the "stealership". Question is, can I drive the car back to Toronto or should I bite the bullet and let the local Audi dealer fix it?
    Thanks for any advice.
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    100k km is like a break-in period for a car :). That's 60k miles. Car in this area usually put on that many miles in about 3-4 years with the long commutes. My S6 has 93k miles pushing over 600whp and going strong. I don't expect any issues for at least another 60k miles with proper maintenance.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Apr 15 2020
    Melbourne, VIC
    I've heard there's no harm running the car with a faulty PCV.
    As long as you can suffer through the noise that is.
    Also I think some people have put a bit of rag underneath the oil cap to allow some airflow into the engine to quiten the noise
    Senior Member Two Rings aistis72's Avatar
    Apr 20 2016
    Vilnius
    My car is 2014 rs6 I have about 130.000km doing oil change after every 15.000km at Audi dealer, sometimes i hear whistle not like this https://m.facebook.com/1554702095/vi...n2YNLJ9wrxYnPh but car goes ok
    Jan 30 2007
    CLS63 AMG
    Prepare for shock and ridicule from American's who recommend oil changes every 700 miles.
