Car can barely run, it shuts off multiple times on startup until i can rev to keep it on. i got multiple misfires on many cylinders and also fuel lean codes and fuel pressure regulator short to plus p2296 and last week it was p2294. Decided to order a hpfp assuming is that pump is shot because i had that same code on my q7 and it was the hpfp. any insight?
Question #2. I need this car fixed asap, had to order an aftermarket high pressure fuel pump the spectra premium fi1503. stainless steel. OE. Any experience with aftermarket hpfp? would this work correctly?
