    Apr 14 2010
    Southern California
    S7 and RS7 engine differences
    What are the internal differences between a S7 and RS7 engines? I know the turbos are different but what about the internals?
    Mar 26 2010
    US
    Quote Originally Posted by EriCal View Post
    BMW M3 Competition X-drive
    Mar 26 2010
    US
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    What do you think it is that adds the 11 lbs to the weight of the RS7 motor?
    Different steel density? The extra (aux) oil cooler, extra HX? Or are those things not included in the engine weight?
    Or is that just a paste from the S8 stats where it has two airboxes and filters and power steering pump and the RS7 motor actually weighs the same as the others?
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 26 2010
    US
    Quote Originally Posted by gk1 View Post
    Unknown.....but note the RS7/S8 block is different since the block is heat treated and has larger main bearings. There may be other structural differences in the block. Maybe they are counting the double air intake and added engine oil/water cooler weight.
