Results 1 to 16 of 16
    Sep 28 2009
    suburb
    How long for springs to settle?
    I got kw has and ride is great but front is a little too high for me. Shop says to let it settle. How long or how many miles should it be for them to settle? Thanks
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Nov 02 2008
    A mess.
    Grapevine,TX.
    At least 2 weeks is what I try for depending on how much driving you do. You might see .25" after the 1st drive a little more in 2 weeks.
    2019 VW Tiguan 4mo SE. Orange, stock for now.
    Former: 91 SHO, 83 5000S Turbo, 78 Supra, 86 Golf, 69 Chevelle SS, 2 Taurus wagons. 72 Olds Toronado
    2001 B5 Passat 4Mo Wagon, 6sp/1.8T swap. Sold.
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    Even when you jack the car up or put it on a lift for a few hours it takes a while to re-settle. Two weeks is fair enough to see when it's more or less fully settled. It should then stay about the same for at least a few years and a good 50k+ miles.
    When I take my car off the lift or off the jack it takes a good 50 miles to re-settle to it's "settled" position, and that's after having the coils for over a year and about 15k on them.
    Mar 11 2019
    Graniteville, SC
    Quote Originally Posted by flyfishing View Post
    Assuming they were installed correctly a few weeks. When mine were installed the installer left the spring perch on which caused my car to sit about an inch higher.
    The black plastic piece inside the red circle has to be removed.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Not removing the lower spring seat is the most common issue with the KW HAS kit sitting too high at the front. The installation instructions are pretty clear so I'm not sure what these shops are thinking of when they do the install, if they are thinking at all!
    Sep 28 2009
    suburb
    Looks like my plastic piece is in there??
    Audi SQ7
    Audi B8 S5 (gone)
    Feb 27 2014
    Dubai
    It's actually steel, they need to remove the HAS springs and tap upwards with a hammer on the spring seat to remove them, they are just a friction fit. The HAS threaded collar then slides down to the current spring seat location.
    Sep 28 2009
    suburb
    Is my black piece the steel piece?
    Audi SQ7
    Audi B8 S5 (gone)
    Feb 27 2014
    Dubai
    Correct
    Print this off for your shop
    http://docs.kwsuspension.de/ea-KWHFS-h68810075.pdf
    Sep 28 2009
    suburb
    argh thanks for the info. i can let it settle then drop it off. there will be no charge for the correction.
    Audi SQ7
    Audi B8 S5 (gone)
    Sep 28 2009
    suburb
    I am having spring kit redone properly in a week.
    Does having that metal piece in affect the car handling in the interim? Does car feel better when it is removed?
    Thanks
    Audi SQ7
    Audi B8 S5 (gone)
    Feb 27 2014
    Dubai
    Difficult to say, you're currently sat an inch too high with incorrectly pre-loaded springs so it may feel different once it's all fitted correctly and the wheels are aligned.
    Sep 28 2009
    suburb
    n/m
    Audi SQ7
    Audi B8 S5 (gone)
    Sep 28 2009
    suburb
    OK I got the springs reinstalled. For anyone with this issue and/or you feel your car is floaty, check the install. Ride is so much better after fixing it and looks so much better too!
    Now I just need my ecodes to arrive :)
    Audi SQ7
    Audi B8 S5 (gone)
    Oct 20 2018
    South Carolina
    Glad to hear you had the KW installed correctly. I’ve been there and done that. Thanks to Jon3 and JamesRS5 quickly pointing out the issue for me back in March.
    Sep 28 2009
    suburb
    Quote Originally Posted by DraiS5 View Post
    AZ saves the day!
    Car is so much better now. Gotta put my td1 sticker on and waiting for ecodes. Ahhh nodding addiction
    Audi SQ7
    Audi B8 S5 (gone)
