Results 1 to 20 of 20
    Oct 19 2018
    Virginia
    2011 C6.5 3.0 Coolant leak
    Somehow it only posted my picture but*I’ve had my 2011 C6.5 for about a year now and it has 97k and some change miles. I had to put coolant in the other day since a nice warning came on to turn off the engine and add coolant. Today looked under the hood and can see a significant puddle of coolant on the belly pan but I cannot tell where it might be coming from. I haven’t had the chance to get underneath to look deeper so I was hoping someone might be able to tell from the picture if there is something that commonly leaks in this area or at least point me in the right direction? I know it’s not the best picture but you can see a puddle in the belly pan. What is the part in the upper circle? That part seems to have some coolant on it and has attracted some dirt so maybe that is leaking? All the hoses and everything below that part looks like it is covered in coolant so I don’t know where to begin. Thanks in advance.
    Established Member Two Rings Big_Reyn's Avatar
    Aug 15 2014
    2002 GMC Sierra, 2005 Toyota Camry, 2018 Infiniti Q50
    DFW
    I experienced that same problem with my 2011 A6 3.0t. My problem was the water pump. I also replaced the thermostat, the cross over tube connecting the heads and I also did my VCG's because they were starting to leak. Check the condition of your belts since they will be removed if it's the water pump.
    Sent from my GM1915 using Tapatalk
    Oct 31 2013
    Land Rover LR3, Harley Dyna Fat Bob, Triumph Speed Triple
    Washington DC / NoVa
    My 2009 has a slow coolant leak as well. Someone posted a few months ago that replacing the reservoir solved there issue. Could be the source of yours as well.
    Deactivated Four Rings
    Jun 23 2011
    If you have a slow leak without any drips or puddles, check your #3 or #6 plug and see how they look. Could be a leaking IC from the SC.
    Oct 19 2018
    Virginia
    Quote Originally Posted by Big_Reyn View Post
    Is the part I circled in the top circle the water pump? I've a visual worker so if I have a diagram or schematic it makes more sense. About how much were all the parts?
    Thanks
    Oct 19 2018
    Virginia
    Thanks for the suggestion. That was actually the first place I looked and nothing in the vicinity of the reservoir has any signs of leaking. It appears to be only leaking from the front of the engine.
    Aug 15 2014
    DFW
    That does look like the water pump, however everything is so tight on our cars it's hard to say definitively. I initially suspected my thermostat was leaking.
    Junior Member Two Rings
    Jul 01 2019
    San Diego/CA/USA
    I had the same issue and I'm currently go thru the process of fixing it. I have a thread and YouTube video on the process. I have plenty info in the video
    https://youtu.be/2rWVqA_4_lc
    Senior Member Two Rings 11A6's Avatar
    Jan 04 2018
    Maine
    The c6.5 cars had a TSB for replacing the water pump/thermostat which is NOT the item you have circled in red - I think that's the vacuum booster. I believe the water pump/thermostat is lower in the engine and may be under the supercharger?
    2011 A6 Avant Prestige w/CWP 1/20
    Oct 19 2018
    Virginia
    I still haven't had the chance to get underneath the car to investigate further. Based on what I've read and your comments I'm leaning towards the water pump leaking. Perhaps that is the problem and coolant has leaked onto the belt which is spraying coolant all over the front of the engine. Can someone give me an idea about what is involved with replacing the water pump? I've been unable to find any videos or detailed instructions about how to do it.
    Aug 15 2014
    DFW
    There are two areas circled in the picture. The smaller circle in the photo appears to be the water pump. The larger circle is the vacuum pump.
    Jul 01 2019
    San Diego/CA/USA
    In this thread I have more info that I think could help diagnose your problem
    https://www.audizine.com/forum/showt...4#post13889884
    Oct 19 2018
    Virginia
    Does anyone have a parts diagram for the 3.0 engine? I'd like to be able to identify all the parts on the front of the engine.
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    The 3.0t and 3.2 belt replacement guides are probably your best bet for getting a handle on which pulley is which. @Big_reyn is right though - the top circle is your vacuum pump (known for leaking oil, which yours appears to be doing), the bottom circle is closer to your water pump.
    The water pump and thermostat are very close together. It'd be hard to detect which one was leaking given the way everything is packaged, however if you replace one you might as well replace the other, since they require the same amount of work to get to.
    It's a full day job for DIY if you haven't done it before, possibly more depending on how things go. You'll be pulling the blower and putting the front end into the service position. I took the time to do several other items while I was in there since it's just so much fun to do both of those things and didn't want to be doing it again soon.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    I wouldn't be surprised if it's the water pump, it's a common enough problem on our cars. If you're having it done, it may be worth doing the thermostat and possibly PCV (if it hasn't been done) as I believe all three reside in the valley, under the supercharger, and typically fail at some point as well.
    Sent from my PH-1 using Audizine mobile app
    Jul 01 2019
    San Diego/CA/USA
    Quote Originally Posted by Mikeythekat View Post
    Literally just click on the link it will lead you to how I fixed the coolant leak issue titled FOOZY Build Sheet
    https://www.audizine.com/forum/showt...C6-Build-Sheet
    with diagrams and all. I am also working on a video edit on how to actually gain access to it all up front.
    Jan 28 2010
    Central NY
    My '10 sprung a leak last week at 135K miles
    The top nipple on the water pipe at front of engine is the culprit!
    Oct 19 2018
    Virginia
    Is the top nipple on the water pipe the one that the small coolant return hose connects to? If it is, that broke by lightly touching that hose. I did a quick patch with a small hose clamp and that's alright for now but I do think there is another leak on that front crossover pipe because when I squeeze the large soft coolant hose on the drivers side I can hear air leaking somewhere in the center of the engine which sounds like it could be from the crossover pipe also. Any ideas? Since I need to replace the crossover pipe, what seals or o-rings do I need to get to replace it? I'm going to replace the thermostat also since I'll have it apart and have the intake gaskets and new thermostat bolts. Is there anything else I need to get or tips/lessons learned from others doing the same repair?
    Jul 27 2008
    09 3.0T A6 Avant
    Do the water pump at the same time. It's right there.
    If you look on the parts diagrams, there are o-rings on each of the pipe connections. I would *highly* recommend getting one of each of those. Good luck, I had a hell of a time separating the connections. The pipe should come with the o-rings for the connections to the block.
    Since the blower came off to do the work, I also did a carbon cleaning, changed the blower oil, and did the PCV (the original reason I was in that area in the first place). I also replaced the coolant pipe that runs under the blower. Not listed as a common failure item, but it seemed odd to me to replace the crossover pipe and not that one (#23 in your diagram)
    09 A6 Avant 3.0t
    01 WJ rock toy
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Quote Originally Posted by stuffinder View Post
    This. I had mine break @ like 60k miles.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
