Results 1 to 7 of 7
    Established Member Two Rings Hard-Knocks's Avatar
    Jan 04 2017
    Raleigh, North Carolina
    S3 OEM vs. Remote Control Exhaust Valve Control
    Manufacturers of new exhaust systems for our cars like AWE and APR provide valve control via a remote and allow the valves to be basically operated manually by the driver (open or closed valve option only). Based on limited research these systems appear to overwrite the OEM valve control. When in Dynamic/Sport Mode I understand that the OEM settings leave the valves open. However, some forum discussions also mention that the exhaust valves are closed up to 3,000 RPM and stay open at the higher RPMs, assume this is regardless of the driver mode you are in.
    My question is, how do the remotes sold AWE, APR and others impact the OEM programed valve switching? Some forums mention that there is loss of power at lower RPMs if the valves stay open and that this could impact the mechanical system. Also, if you leave off the remote control from these aftermarket systems, would assume the OEM valve controls remain active, the exhaust would just sound different when the valves are open?
    Senior Member Three Rings Kevin quattro's Avatar
    Jun 14 2019
    2019 tiguan SEL
    Rockford,mi. USA
    From what I've read they connect to the systems existing valve control unit, so it can still control those aftermarket valves, and then the remotes add the option of pressing on and they're open no matter what, and off no matter what. I could be wrong as I don't own an aftermarket cat back yet, but I have done some research. AWE and remus are my two favorites atm, outside of armytrix, which I would love but are sadly too much money for me.
    Garage: 2017 Glacier white S3 prestige Mods: integrated engineering stage 2 high torque w/ crackle, i.e. tcu, Apr carbon fiber cold air intake, apr cf turbo inlet pipe, GFB DVX dv/bov, CTS turbo inlet, NGK R7437-9 plugs, scorpion cat-back, EMD splitter and spoiler
    2019 Tiguan SEL: sadly stock
    SOLD: 2017 A3 quattro: apr stage 2, apr down pipe, apr carbon fiber cold air intake
    Apr 11 2012
    I found the oem valve operation to be annoying with a turboback exhaust. when you are trying to cruise and fly under the radar your car will be quiet until the valves open at 3k, then suddenly very loud. so its quiet quiet quiet loud loud, quiet quiet quiet, loud loud, as you run through the gears. it gets really annoying when you have to go through half a dozen closely spaced stop signs.
    with them always open I don't notice any power loss.
    with them always closed, I do notice a minor power loss up top when you are redlining and going WOT.
    Jan 04 2017
    Quote Originally Posted by will13k7 View Post
    Thx. Sounds like paying extra for a valved aftermarket exhaust system is really not worth it.
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Also note that the OE setup controls the left and right valves separately...that is, you can have: 1. both close, 2. one open. 3. both open. However, both AWE and APR will control both valves together...so, it's either both open or both close.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Jan 04 2017
    Quote Originally Posted by XMetal View Post
    Did not realize this and it seams the best choice would be to either stay with the OEM exhaust system or install the aftermarket exhaust and forgo the remote controller (deal with quite and loud alternating exhaust sounds). Thinking that sticking with the OEM system and replacing my messed up chrome tips might be the best and cheapest choice. Thx!
    Jun 14 2019
    2019 tiguan SEL
    Rockford,mi. USA
    It depends on what you're looking for. I personally want some more sound and a little more performance. I got a pm from another member who bought the switchpath, but preferred the sound of them always open, and didn't find it too loud for daily driving. I decided I'm going with the AWE track exhaust. non valved. I've never heard anything about losing power with open valves. The manufacturers claim modest performance gains, in addition they're usually lighter than oem. AWE claims 17hp gain, but I'm pretty sure they're including the downpipe in that figure, and they don't show where that hp is coming on. Can't find any mfg showing a power graph. Now you have me curious. If you only care about looks, from what I can tell,you will have to cut off the exhaust tips to replace them, which is super annoying. They're welded on or maybe clip on under the tip somewhere. No screws etc accessible. Either way, if that's all you're after it's the cheaper solution.
