The cut off valve is supposed to prevent heat redirection from the engine until the coolant reaches sufficient value (I assume this to be the ENG105715 value, which roams around in the low 60s C on my car). You can see the block diagram of the coolant routing I modified from the Audi doc here:
https://www.audizine.com/forum/showt...1#post13778760
If you have the vacuum actuated one and a vacuum gauge/hand pump, it should be easy enough to test. I don't know if the valve is vacuum activated or vacuum deactivated. You can see more about the vacuum line routing to it here:
https://www.audizine.com/forum/showt...m-Hose-Routing
Pull the line off the valve and put it on a gauge and see how much vacuum is coming to the gauge at start and then after the coolant has warmed up to normal operating temp. I would expect at some point the N422 control solenoid is activated and the vacuum is passed through to the line, or it could be vice versa.
Then you can plug the line and use the vacuum pump to start with no vacuum, expecting then no heat, and then apply the amount of vacuum you saw from the engine and then hopefully now feel heat.
This of course assumes the problem is not elsewhere in the heat exchange, thus best to start with mtroxel's test of no valve in the loop at all.
So you might have an issue with the N422 solenoid or the shutoff valve.
As for bleeding the system, the Audi HVAC repair manual says to pull the return hose (the right side one, as in right side of the car, not your right side as you stand at the bumper looking back at the firewall) forward exposing the bleed hole on the pipe (this is at the firewall junction, under the plenum cover behind the jump start block). Then pressurize the overflow tank to push coolant into the system. All air is removed when coolant starts to flow from the bleed hole. Slide the return hose back on and resecure. Then repressurize the system (1.0 bar) to check for leaks. If all good, top off the overflow tank as necessary and you're done.
The repair manual mentions "When bleeding coolant circuit, take special care to ensure complete bleeding of heater cores. If there are still air bubbles in the heater core, it may cause the customer to complain of insufficient heating performance in winter or different air temperature from vents at same setting in regulated mode." It also mentions to be sure not to get the coolant pipes swapped. The exchanger doesn't work well with the coolant going the wrong way.
The Audi tools for that would be the cooling system tester VAG1274B (
https://audi.snapon.com/SpecialTools...temId=19150195) and the appropriate adapter for the overflow tank (
https://audi.snapon.com/SpecialTools...itemId=9640195). The leak test procedure says to pump to 1.0 bar, so I assume the same would be sufficient for the bleeding process. For testing the cap, it's adapter
https://audi.snapon.com/SpecialTools...itemId=9650195. The pressure relief valve in the cap is suppose to activate at 1.4-1.6 bar.
One comment on the leak detection process, the manual does say be at operating temperature. I'm not sure you'd really want that for the bleeding process though.
Coolant flush and fill, the filling process is done using
https://audi.snapon.com/SpecialTools...?itemId=120163 . Compressed air is used to build a vacuum in the coolant system, which then sucks the coolant in. This allows for not needing to bleed the system, though I notice the bleeding process is still in the filling process in the Engine Mechanical repair manual - Coolant system section. Better safe than sorry. After filling, bleeding, you then run the engine, A/C off, temps set to Hi, for 3 minutes at 2000rpm, then idle till radiator lines are warm, then 2 more minutes at 2000rpm. Then top off the tank once everything is cold again, if necessary. Damn.
