Results 1 to 7 of 7
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    VCDS to disable automatic Pre Sense braking?
    Question is simply, is anyone aware of the VCDS coding to eliminate the Audi Pre Sense automatic braking?
    My girlfriend's SQ5 has it and she's frustrated that it isn't defeatable; it's tripped several times needlessly and in one instance almost got her hit by another driver who didn't expect the abrupt stop.
    Ideally it would be good to deactivate just the braking component and leave all the other driver aids alone, they don't seem to be any issue.
    Grateful for any help!
    Pic of our cars for attention:
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Jul 31 2016
    PA
    You can turn it off in the menu, but you'd have to do it every time you start the car. Should be under menu, vehicle, driver assistance. Can't help with VCDS, but there is probably a default you can change.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Mar 24 2014
    Quote Originally Posted by djn876 View Post
    We asked when we bought it and they said it wasn't possible to defeat.... I checked also; you can change the sensitivity but even at its lowest setting it's annoying as all hell.
    Jul 31 2016
    PA
    Quote Originally Posted by Project Quattro View Post
    Weird, this is right out of the manual. Maybe it's different for the US models.Screenshot_20191015-214727.jpeg
    Oct 26 2015
    Norman/OK
    you can turn the Pre-warning off and it will stay off, the Pre-sense though has to be turned off at every key on. We have a 2018 S5 in the family and had the same issues as the OP.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Could you not just uncheck the package option with vcds? You can add options, can you not remove them?
    2011 A4 Avant Prestige S-Line
    Mar 24 2014
    Quote Originally Posted by Novarider View Post
    That's what I'm wondering, I no longer have a cable to check since I got rid of my Audi. I can talk to friends about evaluating it but there's no point if it isn't possible.
