Results 1 to 1 of 1
    Registered Member One Ring dsalbatera's Avatar
    Jul 25 2019
    SF, CA, USA
    2006 Audi A3 3.2 VRT
    Please read my whole listing, there’s a lot of modifications as well as extras I’m including with the sale of my vehicle:
    With a heavy heart, I’m selling my 2006 Audi A3 3.2 VRT S-line in Brilliant Red. The increase in difficulty of CA emissions and police patrolling around the roads I drive is a sad reality I have to face. I’d like the car to go to someone out of state where SMOG isn’t required (smog will not be provided with the sale of this vehicle). The car has never been launched, redlined, tracked, smoked in, or had pets in it. It’s an outstanding example of an A3 with a turbocharged VR6 powerplant. It has a 6-speed DSG transmission with paddle shifters.
    I purchased this 2006 A3 3.2 bone stock with 38k miles from Acura of Reno in July 2016. It was owned by 1 previous person that drove it sparingly. Over the last 3 years I’ve owned this vehicle, every maintenance performed and modification installed has been at 034Motorsport in Fremont (they can vouch for this). I have a binder of receipts and work orders. I purchased their last turbo kit September 2018, before they discontinued it (the 034 intake manifold was already discontinued at the time, thus a cast aluminum one from Germany was installed - vacuum lines tapped by 034). It has every drivetrain/suspension component 034 makes, it handles very well.
    The car has been tuned by Nate on the 034 Mustang dyno and makes a healthy 370awhp, on CA 91 octane, 12-13psi. It has a DQ250 DSG tune as well, also done by Nate. Note that the turbo has a .82 a/r hotside housing as recommended by the shop in the car’s current state (stock short block), a .63 housing is available through Precision if the next owner wants to swap it out. The head has been decked and valve, valve springs, and retainers upgraded, guides changed.
    The exhaust is a full v-band, custom stainless steel 3.5” from the turbo all the way back out to the car, welded/fabbed by Sonu at 034. It has a custom 3.5” high-flow cat, no muffler. The car is loudest on cold start and WOT. The sound unmatched by any other car out there, it’s menacing and raw with backfire sounds and burbling. It has several v-band flanges, one of which is near the rear axle, so the rear piece can be removed and replaced with a custom muffler section if you so choose.
    Overall, this is a very well balanced car in its current state. It has the potential to make a lot more power with forged internals, though some argue a stock VR6 24v block can take a lot more abuse. It is not a show car, it was built to be driven. It takes about a minute to get warmed up on initial cold start, after which point, it drives like a charm. There are some minor external blemishes, please read below.
    Serious inquiries only, no tire kickers. Buyer will need a second vehicle to assist in transporting all the extras included with sale.
    Price/photos
    $30k firm - includes extras, clean title, car sold as-is
    Photo link: https://imgur.com/a/nKnFxTT
    Short video, cold start: https://youtu.be/bp5RPiWTj4o
    Includes 2 extra set of wheels, and a lot more (check the bottom of the listing), will not include CA vanity plate
    Not interested in trades at this time
    Car is located in SF, CA
    E-mail if interested: domsalbatera @ gmail . com
    General Information
    ~55k miles, 10k miles with turbo kit
    All maintenance and modifications done at 034 Motorsport, Fremont, CA
    370awhp on the 034 Mustang dyno, 12-13psi, CA 91 octane
    Clean title, I’m the 2nd owner
    Takata airbag has been changed by Audi SF
    Oil pump, hydraulic intake/exhaust cam lifters replaced with OEM units at time of build
    Engine
    034 stage 2 turbo kit with Precision 6262 ceramic ball bearing turbo, .82 a/r, custom tune
    Garrett 600 intercooler
    Tial 38mm wastegate, 12psi spring
    034 bypass valve
    034 X34 cold air intake
    034 head spacer kit, 8.5:1 compression
    ARP head studs
    Supertech intake/exhaust valves
    Supertech valve springs, titanium retainers
    034 custom 3.5” stainless steel turbo-back straight pipe, v-band
    034 custom 3.5” high-flow cat
    Cast aluminum short runner intake manifold
    85mm slot style MAF
    034 billet fuel rail
    Bosch 4 Bar FPR
    DeatschWerks DW65v fuel pump
    034 DSG tune
    Suspension/Drivetrain
    KW V3 coilovers, 2” drop all around, shocks are currently 1 click stiffer than KW factory setting
    BBS RF forged wheels (ceramic coated), 18x8 et48
    Michelin Pilot Sport 4S tires, 235/40, lots of life left
    ECS titanium lug bolts
    034 5mm spacers, rear
    Ground Control camber plates
    SuperPro aluminum control arms, front
    ECS stainless steel brake lines
    EBC slotted rotors, EBC Green Stuff pads - lots of life left in these
    034 rear swaybar
    034 front/rear motorsport swaybar endlinks
    034 rear upper adjustable control arms with aurora spherical bushings (no longer sold)
    034 rear toe links
    034 trailing arm bushings
    034 rear subframe inserts
    034 front subframe locking kit
    034 billet dogbone mount
    034 dogbone mounts
    034 lower dogbone insert
    034 motorsport engine/transmission mounts
    ECS skidplate
    HPA Haldex controller (Gen. 2), HPA wireless remote
    Interior
    P3Cars digital gauge
    Ziza LED lights
    Custom flat-bottom steering wheel by Reggie’s Custom
    ECS carbon fiber paddle shifters
    OEM sport pedal set
    OEM all weather mats, Weathertech rear trunk
    3M Crystalline clear tint on windshield, 5% tint strip at legal 4” line
    Tint on all other windows was done by previous owner, unsure on VLT% - 1 minor blemish on passenger side tint on window
    Exterior
    OEM black grille, OEM black plate filler
    Ziza LED license plate bulbs
    ECS smoked side markers
    PIAA Solar Yellow foglights
    034 plate frame
    Xpel film protection on front bumper, hood, front fenders, side mirrors, door cups, center rear bumper, lower rear fenders
    Ceramic Pro on body, wheels, windshield
    Included extras, not installed
    HPA 4 pot rear BBK, 335x28mm rotors, black calipers - brand new, in box
    1 set of OZ Leggera HLT (also ceramic coated) with tires: 17x8 et48, 235/45 Michelin Pilot A/S 3+ (2 tires replacing soon), spare lug bolts
    1 set of Audi OEM mesh wheels with tires: 18x7.5 et54, 225/40 Sumitomo HTR A/S P02 tires (came with the car, appears to have been repaired from rash), spare lug bolts
    Additional 034 5mm wheel spacers
    Thule Aeroblade roof bars/mount, will include key for security locks
    OEM Audi sunshade
    OEM air vent (replaced by the P3Cars gauge)
    LEDPerf DRL LEDs, titanium front turn signals, rear LED turn signals, LED accent lights
    Unibrace UB underbody brace (painted red) - will need their deep nut kit to work with 3.5” exhaust, or some other modification
    Dr. Colorchip touch up paint, Brilliant Red
    Cosmetic defects
    2 light dents on trunk hatch above license plate, 1 ding on driver’s side fender - these shouldn’t be too hard to pull out by a paintless dent shop
    Tiny paint chip on passenger A-pillar, and passenger door molding
    Ceramic coating was applied with Thule roof bars and box still on the car at the time, so the coating is missing in 4 small areas on the roof
    Minor Xpel film bubble on the passenger fender, film on lower front bumper was peeling slightly and was cut
    Air conditioner needs to be recharged
    Thank you for your interest in my car, if you have any questions, please e-mail me: domsalbatera @ gmail . com.
    IG @dominicsalbatera
