Results 1 to 40 of 43
    Oct 01 2019
    tampa
    Issues with 16' S7
    Hello, this is my first time posting on here, mainly due to issues I'm having with my recently bought 2016 S7
    After driving it hard, the car starts reeking gas throughout the whole garage
    And when I drive it hard for a longer period of time, it starts smelling like gas inside the cabin too. Last weekend I had to pull over and park it for a while because I was getting dizzy from all the fumes.
    I've had the car serviced before and they couldn't find any issues, and they said they told me "cars like these tend to smell like gas". I took it back in today for further inspection because I just didn't feel safe to drive it anymore.
    When I bought the car from a dealership in Texas, they specifically said there is no modifications to it and it's still under warranty.
    Today the Audi dealership I'm having the car serviced at messaged me saying that the car is tuned, and that voids my warranty, and if any issues pop up I'm going to have to pay out of pocket.
    This is my first audi, and so far it's been a horrible experience with some other issues when getting it delivered.
    Please let me know what you think the issue could be or just any advice.
    Thank you
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    Does it run funny, is your gas cap closed? Does it run out of gas fast or use it quickly? Do you see any gas coming out? Probably bad gas cap. Tooo new to need anything else.
    Deactivated Four Rings
    Jun 23 2011
    Look under the engine cover and see if it has downpipes. Some of the downpipes are known to smell.
    Oct 01 2019
    tampa
    Runs fine, gas cap is closed.
    It does run out of gas fairly quickly, but I do get about 13 MPG. Haven't seen any gas coming out or any leaks.
    Anything else you can think of?
    Mar 23 2019
    KS
    If it was tuned without your knowledge do you have catless downpipes?
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    pull the engine cover and take pics toward the back (firewall) of the motor, around the turbos.
    2016 S6 - sport - optx- atlas - AE nardo
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    After checking for downpipes, if that's not it then yank the rear bench seat up and see if it's wet around the fuel pump.
    Have someone rev the car while you watch around the high pressure fuel pumps in the engine bay. Those can leak fuel if someone didn't tighten up the hard line enough.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Apr 06 2016
    so cal
    Quote Originally Posted by esemes View Post
    bingo.
    I'll pretend to be shocked when I see APR or simply catless downpipes
    Slovenian tin exhaust, some worthless intake that isn't the SRM yet, cete valve controller because the akra one doesn't work properly on c7.5, apr stage 1 ecu/tcu, 5(five) bbs ci-r's because my car loves potholes, Eurocode sways/links, Eurocode alu-kreuz, and an undying love of hard parking
    Dec 07 2016
    Long Island
    I hope you have it in writing that it is still under warranty from the first dealer.
    Sent from my SM-G975U using Tapatalk
    Oct 01 2019
    tampa
    Quote Originally Posted by Faceman76 View Post
    Yes, when I purchased it they told me it has no mods, and that it is still under warranty.
    Oct 01 2019
    tampa
    The car is still at the audi dealership and they're trying to recreate the issue. But so far they havent found anything....
    I did ask the service guy to check for downpipes, and he said there's none, so I'm guessing its some sort of stage 1 tune (but I will take some pictures when the car is back)
    He keeps saying that the smell is coming from the vehicle having to burn more gas since getting pushed hard...?!!? but having to smell it inside the cabin is beyond ridiculous
    @ericw As for the fuel pumps being loose they said everything looks normal no leaks no nothing...
    If you guys have any more ideas on what it could be let me know
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by slo s7 View Post
    did u purchase it at an audi dealer?
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Senior Member Three Rings Cris_OO7's Avatar
    Jul 08 2010
    Woodhaven/NY
    BS answer from dealer. Find yourself a good indy shop and never look back again.
    Jul 02 2019
    clearwater florida
    What in the world makes sense of that explanation? It sounds like how I explain some tech things automotive to my Mom... She loves cars, every chance to get a new one, but that is just odd. For the record, she believes there is an exhaust leak - the tune is easy to determine once plugged in.
    Oct 01 2019
    tampa
    The car was purchased from a range rover dealership out of state
    I've been having it serviced at a local audi dealership
    Jan 07 2011
    2013 C300 4Matic
    Issues with 16' S7
    Im curious. Is RR dealer at fault for saying its under warranty ? What if the car was never plugged in and never flagged, so no td1, hence having warranty. Traded in to RR and bought with warranty. And the moment u plugged into the ecu @ audi, ur warranty voided.
    Cars with tunes and never plugged in , is considered to be under warranty. Only when u get ur ecu plugged into the system @ audi is when tune is detected. So it sucks that u didnt know u had a tune, u coulda possibly asked audi to not plug in, preserving ur warranty
    Present:
    IG: bknewtype
    Oct 01 2019
    tampa
    Apologies if the way I explained the situation didn't quite make sense, but I'm fairly bad with car stuff, it's just a frustrating experience that I'm in now and don't quite know what to do
    Oct 01 2019
    tampa
    Quick update to the situation, the car went through a multi point inspection, and everything looked good, no issues.
    But the smell is still there when driving it hard...
    I've been trying to figure out what kind of tune is on the vehicle right now, and the audi dealership says they're not able to. Apparently best way to find out is "Getting in contact with the previous owner" (Which is almost impossible since the car was traded in at a dealership in Utah, then then sold to the RR dealership i got it from in TX)
    The audi dealership suspects the tune is causing the gas smell, and they're offering to revert the tune back to stock for 1.8k...
    What should I do?
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    APR seems to be a popular tune to get on these. Contact APR and give them your VIN and they can look it up in their records to see if its their tune. I would bet they can detune it for a lot less than $1,800.
    Jun 09 2017
    Signature
    GTA
    What are you going to do about the fact that you were told by the selling dealer that there was no mods ? Are you going to fight to have OEM full warranty? If you pay the rape charge of $1.8k for the stock tune, is the dealer willing to drop the TD1 flag on the car and honor the full warranty? If so, I'd go that route...
    Or if you are ok with losing your warranty, go ahead and get a proper tune from a reputable company for peace of mind and so you can rule out any sub-standard tune as the cause..
    IMO the tune is not the cause of your gas smell, but I'm also not sure what it could be other than an exhaust or evap system leak (which wold ultimately throw a code)... Down-pipe leak makes the most sense. to me..
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Jul 02 2019
    clearwater florida
    if the car was sold with non-oem downpipes, it is illegally sold. (from a dealership)
    Jan 28 2015
    B9 S4, QX60, 69 GTO
    MA
    Were the Spark plugs recently changed? if the spark plugs weren't tightened all the way, you can smell gas in the cabin also.
    Active Member Two Rings isellpower's Avatar
    Jul 26 2018
    2017 RS7
    El Dorado Hills, CA
    Upon discovery of the tune, I'm going with something cat related. They tuned it and did high flow cats or removed them. Went cat-less on my Viper and it was the worst decision I ever made. Horrible gas fumes, all the time.
    Oct 01 2019
    tampa
    Got the car back from the dealership, and they couldn't find any issue
    checked for gas leaks, took the back seats out and checked for that spot too, exhaust leaks, and a bunch of other things..
    apparently nothing is wrong, and when they drove it they couldnt smell anything
    if the car is driven normally, there is no gas smell, but only when I drive it hard like top speed runs and stuff like that it starts smelling horrible. They couldn't resolve anything and told me to come in when it smells like gas...
    About the tune, they told me they couldn't figure out what type of tune it is, and I'd have to do that on my own.
    Does anyone know how I could find out what type of tune it is? I've been emailing some tuning companies with my vin number just like the suggestion above, but no luck
    What are some popular tuning companies for the s7? I've emailed APR so far.
    Jul 08 2010
    Woodhaven/NY
    Can u post a pic of the top rear of your engine with the cover off. That could help determine what stage tune is the car.
    Oct 01 2019
    tampa
    Quote Originally Posted by Cris_OO7 View Post
    Couldn't figure out how to attach them, so i uploaded them here "https://imgur.com/a/Pk2JO1T"
    If that's not good enough let me know I can take more
    Last edited by slo s7; 10-13-2019 at 03:25 PM. Reason: forgot to take off engine cover off
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I agree with others to take it to a good vw/audi indy shop. I swear dealerships lose their minds when they know the car is tuned. Few thoughts:
    1. Is it smell of fuel or exhaust?
    2. Dont pay the stealership $1800 to tune back to stock!!!! Depending upon the tuning company, you may be able to switch back to a stock file little to no cost. And if you have some unknown custom tune, you can buy an ots tune from apr and get a stock file loaded to your vehicle as well. No way is Audi going to reinstate your warranty now so do not pay them to flash it back.
    3. It would be a long shot but the prior owner could have gutted the stock cats. Easy way to check is take out the pre cat O2 sensors and put a scope down there.
    4. Check for exhaust leaks especially if there is aftermarket exhaust.
    5. If plugs are fouled or worn then you could be getting incomplete burn. This is my guess.
    Hard to say what else without any info like codes, logs or pics.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Jan 26 2015
    CO
    Lol he didn’t even do it.
    Op, help us help you damnit!
    Oct 01 2019
    tampa
    Quote Originally Posted by Hofahome View Post
    Thanks for the info, could you elaborate on the "ots tune"?
    Also I attached some photos at the link I posted above
    - - - Updated - - -
    Jan 07 2011
    2013 C300 4Matic
    - - - Updated - - -
    Ots means off the shelf. A tune u just go to the dealer to load up on with nothing catered specific to ur car + specifications. Basically a tune that can b applied to a bunch of other cars
    Present:
    IG: bknewtype
    Jul 08 2010
    Woodhaven/NY
    Looks like stock DP in your pics so u should be just stage 1 unless original owner put stock DP back but left it stage 2. When you’re refueling do u fill up until the pumps stops or do u keep filling it up to the brim?
    Mar 29 2014
    Hampshire, UK
    I’ve never heard of a tune causing a fuel smell in the car. I’ve been stage 1 (APR) for over a year and no issues.
    Didn’t I read a while back about a TSB connected to leaking fuel rails? (Or was that the 3.0T?)
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jul 08 2010
    Woodhaven/NY
    16 is post facelift so it has over fueling map for the crackles and pops could that be what is causing him to smell fuel after a hard run? 🤷🏻*♂️
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    You should take it back to the dealer, ask that a technician or, better yet, the master or lead tech ride with you, and drive it the same way you do to produce the smell.
    That’s the only way...
    2020 BMW X5 M50i | 2017 AUDI S7 (gone)
    Aug 11 2016
    CA
    Quote Originally Posted by Frenetic View Post
    This is right. They won’t push the car.
    Oct 01 2019
    tampa
    I never really fill it up to the max, maybe like 80% everytime. Should I be filling up to the max?
    Oct 01 2019
    tampa
    Quote Originally Posted by RAF_S7 View Post
    Nice s7, same color as mine! How do you like the APR stage 1? Is it worth the upgrade?
    Dumb question, but would it be possible to get a apr stage 1 tune to override mine? Or would I have to go back to stock and then get the apr 1?
    Apr 23 2011
    Sac Area, CA
    What tune do you have? I've heard of a bricked ECU that was tuned by GIAC and overwritten with APR. Ideally you should flash back to stock.
    IG @lolzhax
    //AGILITYDRIVES.US
    Oct 01 2019
    tampa
    Quote Originally Posted by ericw. View Post
    Don't know what tune I have, what's the best way to go about it and finding out?
    Jan 07 2011
    2013 C300 4Matic
    Contact every tune company with ur vin lol
    Present:
    IG: bknewtype
