Just like the title states how can you manually turn the crank to close valves on a 2.0t?
Starting doing carbon cleaning myself and need to close the valves but my ratchet is too short to reach it, and my breaker bar is too thick to fit in the space with the socket on it.
I just want to make sure there isn't another way to do it before I go out and try and get a shallow socket or a longer ratchet. I've searched but only found 1 diy that said jack the car up and do it from the bottom but I wont be able to jack the car up to get under it now.
Also just to verify the bolt on the end of the crank is 24mm?
