Did anyone get this error code in VCDS for a 4.0TT V8 engine before?
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H61 0009
Revision: NCH61---
Coding: 1A2500326526000E1000
Shop #: WSC 03818 003 1048576
ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 211FE613E148A75FE57-8074
2925 - Knock Sensor 2 (G66)
P0333 00 [237] - Signal too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 140968 km
Date: 2019.10.05
Time: 08:03:46
Engine speed: 1936.50 /min
Normed load value: 20.4 %
Vehicle speed: 112 km/h
Coolant temperature: 94 °C
Intake air temperature: 27 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.371 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0000 0000
There are no other codes stored other than one related to the exhaust valves, so it makes me think it's just the G66 Knock Sensor going bad and/or maybe the wiring associated with it. Has anyone have experience with this code or maybe has an idea what else it can be?
For reference, there's the other code, however it doesn't make the Check Engine (MIL) light come on:
17875 - Exhaust Pressure Control Valve
P0475 00 [047] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 140887 km
Date: 2019.09.30
Time: 08:15:30
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 9 °C
Intake air temperature: 10 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.614 V
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
The car drives fine even with the Check Engine light ON. I don't feel any unsual movement/knock in the engine and I guess that if something was really wrong, more codes would pop up, like misfires and or timing issues. I can be wrong though. Any help is much appreciated! Thank you !
