Originally Posted by
Kenny147
Thanks for the replies, gents. I just had a quote to replace the slave, flush and replace the brake/clutch fluid, as well as fit new DP’s and to honest, I might as well go ahead and do the entire clutch.
How much were they quoting you?
The reality is if your doing the DP’s and later on the Clutch, the DP’s need to be removed again so theres shared labor costs that you can take advantage of.
For the usp slave and line there is no need to remove items and seems pretty straight forward, I think it was 300$ when I had that done.
Although there are a lot of posts about changing the clutch the one I’m attaching below is pretty fresh as it was posted recently, has some part numbers, etc.
If you do decide to change the clutch make sure you also include some maintenance items like the rear crankshaft seal and a coolant sensor as it’s all easillay accessible once the transmision is off.
https://r.tapatalk.com/shareLink?sha...3&share_type=t
