Originally Posted by
EvolutionArmory
And let’s look at “simple sense” things that make your car stall when it’s cold.
Carbon build up on the injectors. You have made it known that you’ve had the car for 12 years and haven’t had a carbon cleaning done.
Intake runner flap problems. You’ve had the flaps deleted so right off the bat you’re at a disadvantage because the tumble flaps are there to assist in cold starts and low RPM and idle situations.
Your throttle body is the main component that controls idle speed
A possible torque converter situation if you have an auto.
Since your issue only happens for a few minutes before the car reaches operating temp, those are the components I would look at first.
Regarding carbon cleaning. I just had a new clean head installed over the summer. No change in cold weather stalls compared to the old head. Maybe I should have installed new injectors but why would fouled injectors cause issues only when it's cold?
I cleaned the TB a few months ago. Same with the MAF meter.
Like I mentioned, the runner flaps have been deleted for a few years. The problem started last winter.
This is a temperature related issue. When it's cold the ATF is very thick. It wasn't OEM fluid that was used when I had the two tranny services. It could be the TC. If it is I will have to let the engine warm up at cold starts to prevent the near stalls when stopping.
Coolant temperature sensor?
