I've used Motul since day one of ownership of my RS5 and had been using the Specific 502 00 5w-40 and the X-Clean 5w-40. I change my oil about every 5K miles.
My last oil change I decided to make a switch to Liqui-Moly, specifically the 4100 Top Tech 5w40. Car ran fine, engine was just as quiet overall but my oil consumption went from zero to about 1 liter in 5,000 miles. With Motul, I'd had virtually zero oil consumption with the exact same driving habits. The oil gauge never really moved.
I decided to switch back to Motul, this time the X-cess 8100 5w40. I did a ton of research and spent quite a bit of time on the "Bob the oil guy" web page until acronyms made my head explode and left me with a less clear path to well, clarity. I also read about Motul loosing a lawsuit in Europe recently as some of their formulations were using group III oils and not true group IV synthetics. I'm not sure if the 8100 falls into that category but from what I understand, it's a higher "grade" than even the Specific.
In the end, I decided my prior experience of very little oil consumption with the Motul pushed me back in their direction after looking at a host of options from Pennzoil, Castrol (OEM), Mobil 1, Redline, etc...pouring over all their specs and taking price into consideration. I decided to try the X-cess as it has good viscosity at 100C, a Noack rating just below 10% and a high VI. I don't care much about winter performance as it doesn't get super cold here.
My next oil change, I'm going to try the Motul Sport 5W40 which basically sits between the 8100 line and the 300V line. It'll work in a road-driven vehicle over an extended interval unlike the 300V and it's a true Ester base. But the best part is the Nowak rating is only 4.7% and it has a very slightly higher VI and viscosity at 100C. I think this is the big detriment to the OEM Castrol which seems to have a higher Nowak rating which doesn't help when it comes to carbon buildup.
Tech sheets for the various oils mentioned above;
https://pim.liqui-moly.de/pidoc/P000...40-38.0-en.pdf
https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492016155
https://d23zpyj32c5wn3.cloudfront.ne...pdf?1303836523
https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492017750
