Results 1 to 8 of 8
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    Cool 2017 S8 Plus Mid Muffler Delete and Rear Muffler Delete
    Removed center muffler / suitcase and replaced with x pipe .
    Removed rear mufflers.
    Tips from Aliexpress
    Turned off soundaktor via Obdeleven , and had a friend reset the ANC via Vagcom.
    No valve codes although I have the valve Sims but haven’t installed them.
    Zero to minimal drone. I am sensitive to NVH but was not irritated with this . And as the ANC recalibrated it is getting better inside the cabin. Outside still sounds as great as it is.
    Total spent : 360$
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Nov 01 2018
    ny
    May 10 2015
    Pittsburgh PA
    That sounds awesome, makes me wish I didn't have a little 2.0T haha
    Apr 05 2020
    Tampa, FL
    Question. What X pipe and what size piping did you use?
    Thanks! Sounds great.
    Jul 29 2016
    PA
    Quote Originally Posted by Knee2Neck View Post
    Xpipe: no name brand. Whatever the muffler shop had laying around , and used whatever stock size piping is, didn’t change sizes.
    Apr 25 2020
    Rochester, NY
    Jul 29 2016
    PA
    Quote Originally Posted by GDurf View Post
    This sounds great.
    What did you do to it ?
    Apr 25 2020
    Rochester, NY
    I wanted to go with a GTHaus GTS Exhaust but at $5k I wanted to make sure it was worth what I wanted it for. I wanted more sound rather than performance. My care is APR Stage 2 so I am in no need of power (especially at a cost of $5k for negligible hp).
    It has APR downpipes with the mid resonators removed as well as the rear mufflers. I absolutely love the sound. It does have some drone, but I gladly take it because it sounds so menacing. I was able to retain the stock valves as well. Although the sound change is barely anything between the valves open or closed, but what it does is allow for incredible crackles and bangs on downshifting. I can post a video inside the car showing this as well as a driveby, if interested.
    Very happy with my decision, which was a total of $400 for labor and piping.
