Anyone have any information on error code B11D5 ?
I have intermittently gotten this code associated with a warning on my dash saying 'coolant temp too hot- pull over and let engine idle'
The exact code on VCDS:
0560- Supply voltage terminal 30 for Coolant Pump
B11D5 15 (008) - Open or short to Plus
Intermittent- Confirmed - Tested since memory clear
I've only found one other thread mentioning this error here on AZ- that individual had his thermostat replaced, but I don't know if it fixed the problem or not, as he's not responded to a PM.
Thanks in advance if anyone knows the answer to this.
