Results 1 to 9 of 9
Thread: Aodhan wheels
    Veteran Member Three Rings UltraS4John's Avatar
    Sep 16 2006
    2013 Audi S4
    Northern VA
    Aodhan wheels
    Anyone with Aodhan wheels? The LS002 are very similar to Avant Garde M590’s.
    Wondering if they’re decent quality. Thanks
    2013 Audi S4 - Brilliant Black (Prestige) DSG + IE Stage 1 & STaSIS exhaust
    2013 VW GTI - Carbon Steel Gray Metallic DSG + APR Stage 1 & AWE exhaust
    2018 Audi Q3 - Daytona Gray Pearl DSG
    Active Member One Ring Slow_B8.5's Avatar
    Nov 05 2018
    Tempe, AZ
    I am about to pull the trigger on a set. The only thing holding me back is that I am worried about a 19x9.5 ET35 setup rubbing with my H&R OE Springs.
    Sep 16 2006
    2013 Audi S4
    Northern VA
    Which color? I’m considering gun metal on my black B8.5
    Nov 05 2018
    Tempe, AZ
    Quote Originally Posted by UltraS4John View Post
    I was looking at both the LS007's and the LS002's in Gunmetal. I have a Monsoon Grey B8.5. I really would like to do bronze, but I think that looks better on black or white cars. I have combed the forums and cannot find a definitive answer to whether 19x9.5 ET35 wheels wrapped in 255/35 Michelin PS 4S tires will rub or not when lowered with H&R OE Springs. Some say it is fine, some say it'll rub a ton. I have no problem trimming fender liner and/or filing a bolt, but I do not want to go through the hassle of rolling and possibly pulling fenders. I've done that with my past two cars already and would like to keep this one an easy-going daily.
    Sep 16 2006
    2013 Audi S4
    Northern VA
    H&R OE springs about 1.5” drop? If so, I wouldn’t think they’d run unless you went lower. You running stock shocks? Curious. Btw, I’ll prob end up getting gun metal for my black S4. I’m considering from eBay. What about you?
    Veteran Member Three Rings slowone11's Avatar
    Feb 15 2015
    Castle Rock Colorado
    You should be fine. I had VMR 810 19x9.5+40 with 8mm spacer front and rear. I was on eibach sportline.
    Sep 16 2006
    2013 Audi S4
    Northern VA
    Looks nice
    Nov 05 2018
    Tempe, AZ
    About a 1.2" drop. I am running stock shocks. I have not had them on for long. I'll be picking up a set from Ebay probably too unless I can find them cheaper somewhere. I am still in a fight with myself over bronze or gun metal.
    Quote Originally Posted by slowone11 View Post
    Wow, that fitment is on point! Did you have a lot of rubbing? I am assuming you cut out some fender liner and rolled your fronts.
    Feb 15 2015
    Quote Originally Posted by Slow_B8.5 View Post
    I never rubbed on the fenders. I hit the liners every once in a while.
