Hopefully someone else will find this useful.
The rear license plate bracket was stripped out when I bought my car, even damaged the paint due to the nut spinning. A new bracket cost anywhere between $100-$140 which is ridiculous especially for something that just holds the plate in place. I bought this bracket on Amazon and installed it today. Nothing needed any modification, it just bolted right on. I used the original screws and the washers that came with the new bracket. However, if you want to use a license plate frame, you will need longer screws that what came with the bracket. I'm making this post because I couldn't find much information on after market brackets. I found some saying they used 3M tape on the back of the nuts which I tried but that was just a "band aid". Below is the link to the bracket and photos of the installation.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Original Bracket (Stripped)
Post Removal (3M Tape Mess)
Clean Trunk
New Bracket Installed
New Bracket with Plate Installed
