Results 1 to 40 of 42
    Veteran Member Three Rings texadelphia's Avatar
    Jul 05 2016
    2008 A4 Avant 2.0T Tiptronic
    Grease on brake pads?
    Do you guys put grease on the back of your brake pads where they contact the caliper and the piston? Watched a couple youtube vids and it doesn't look like people do that on the B7s. Is there some reason not to?
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Yes. I lubricate all metal-to-metal surfaces (except brake rotor to hub and rotor to wheel).
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
    Apr 10 2019
    Winterpeg
    Yes as well. All pins and sliders get lubed and the back of the pads.
    Veteran Member Three Rings griga's Avatar
    Jun 30 2017
    Central Jersey
    I only did it because my Hawk pads came with some so I figured why not
    Silver 2008 A4 2.0T | Thermal R&D Exhaust | Cupra R Lip | 034 Mounts | Peelers w/ Spacers | Custom Intake | Paint Matched Reflectors | B5 Perches |
    IG: https://www.instagram.com/rigadesigns/
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Quote Originally Posted by gotrek View Post
    Ditto. Use the lube that comes with the pads or CRC Disc Brake Quiet (has done a nice job with our B7).
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Aug 14 2014
    1987 Alfa Romeo Quadrifoglio, Jeep 2.0 Wrangler Sport, 1979 P200E Vespa , 2005 Triumph Bonneville
    I use lithium grease on the slide pins and copper anti-seize on all contacts (metal on metal). Love this product:
    Jun 27 2011
    CRC brake quiet on the backs of the pads. I don’t normally lube anything but the slide pins but maybe I should since I’ve noticed a rattle down there on occasion. Might check out that loctite copper anti-seize.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 05 2016
    Two packets of lube came with my pads so I'll use that on all the sliding surfaces and the back of the pads. Also bought some permatex caliper grease if there isn't enough in the packet for the slide pins. I also have a jar of permatex copper anti-seize to put on the hub behind the rotors.
    Sent from my moto x4 using Audizine mobile app
    Feb 15 2016
    Cambridge,Ontario
    yes I do but do NOT mix greases. if you have to use them in separate locations.
    Believe it or not after over 40 years of wrenching cars and brakes I find the best stuff for brakes is Sil Glide ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 14 2014
    Found out about it when I was doing the rebuild on my sons Bonnieville. A must have now in my toolbox.
    Jul 05 2016
    I definitely wouldn't mix them and I'd prefer just to use only what came with the pads, especially since the paperwork says they won't warranty them unless you use the grease they supply, but it's such a small little packet.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by DC5 View Post
    You should be using urea grease on the slide pins. Not lithium grease.
    Sent from my SM-G960U using Audizine mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jan 21 2014
    GA
    I use Permatex Ceramic Extreme Brake Parts Lubricant if CRC is not available.
    Mar 04 2019
    Staten Island, NY
    Slides and contact points a must.
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    Apr 10 2019
    Winterpeg
    Careful with antiseize. It will be fine on pads but I would not use it on slides and pins. Antiseize uses softer metals to stop galling by creating a wear layer but on moving parts it can eventually form a chemical bond fusing different metals together when the grease in it dries.
    Sent from my SM-G950W using Tapatalk
    Jul 05 2016
    So I was just looking at elsawin and the instructions indicate that you should lube the pad and spring clip guide surfaces with polycarbamide grease, but it doesn't say anything about lubricating the guide pins.
    Jun 27 2011
    When you’re servicing the calipers you should absolutely grease the slide pins with caliper grease. Unless you want them to rust together and cause the calipers to fail.
    Elsawin probably doesn’t show it because it’s not strictly necessary when replacing the pads and rotors. But it’s smart to clean and relive the slide pins regardless. When I’ve cleaned up older calipers the slide pin grease is always super nasty.
    I use Permatex Ultra Disc Brake Caliper Lube and it’s always served me well for the slide pins.
    -CP
    2017 Q7 3.0t
    Jul 05 2016
    Reading some mixed reviews about the permatex stuff. A lot of people seem to have issues with the rubber boots swelling and binding up the pins with the Permatex. I think I'll try to track down some Sil-glyde for the pins and use what came with the pads for everything else.
    Mar 04 2019
    Staten Island, NY
    Sil-glyde for slides and all contact points. High heat and moisture resistant
    Jun 27 2011
    Quote Originally Posted by texadelphia View Post
    I used the permatex green on my current brakes when I did them about 5 years ago. I’m replacing them soon with S4 parts so I’ll report on how the green stuff has held up. I would expect just fine given how I’ve really had zero issues with them since I serviced them. Just sick of my garbage store-brand rotors getting gummed up with deposits and faintly pulsing through the pedal. And I can’t pass up an opportunity to upgrade to S4 brakes.
    Btw I used the same can of permatex green on my b6’s S4 brakes almost 7 years ago that, as far as I know, are still working just fine.
    -CP
    2017 Q7 3.0t
    Dec 04 2011
    Kansas City, KS
    This is what we used at Acura when i was a tech there a few years ago. Great stuff.
    https://www.amazon.com/Genuine-Honda.../dp/B00BFDFYKW
    Jul 05 2016
    Quote Originally Posted by vvenom800tt View Post
    If I could find urea grease locally, I'd definitely use that as that's what the workshop manual calls for.
    Jun 27 2011
    No local Honda dealer?
    -CP
    2017 Q7 3.0t
    Jul 05 2016
    I read somewhere that Honda dealers don't sell it. Guess I'll confirm with a phone call.
    Jul 05 2016
    Turns out the internet lied to me. $20 at my local dealer.
    Jul 05 2016
    I think I'm going with sil-glyde on the pins. The interwebs seem pretty unanimous on it working well and elsawin doesn't specify. Just going to get a bottle brush and clean out the the pin holes really well to prevent mixing it with whatever was used on my car in the past.
    Dec 04 2011
    Kansas City, KS
    Try Acura, maybe sell it cheaper? Who knows.
    Jul 05 2016
    Not really concerned with cost. Just want to use the best thing. As far as I can tell the reason polyurea is used is due to its high temp resistance. Sil-glyde seems to have similar high temp resistance and a lot of people say that it works well. Plus I have 4 packets of it and the Honda dealer is a 45 minute drive. I'm not sure how well either helps with corrosion prevention, but there are a lot of testimonials out there backing sil-glyde.
    Dec 04 2011
    Kansas City, KS
    Yeah its definitely good stuff the urea grease. It'll handle whatever temp you throw at it im sure. I use it on my rear brakes with no issues at all. My slide pins move with ease.
    Jun 27 2011
    Realistically, any of these greases is going to provide roughly the same lubrication and likely corrosion prevention properties. I’m still perfectly happy with the permatex stuff unless I pull my brakes off and they have swollen boots in which case I’ll try the sil-glide
    -CP
    2017 Q7 3.0t
    Feb 15 2016
    Cambridge,Ontario
    yup I used Permatex on my sons car becasue I ran out of my syl glide... was awesome glue... glued the pin in the carrier in just over a year.
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    they do have different grades .. I can tell you the stuff in the green container is absolute crap...
    https://www.permatex.com/tech-tips/g...st-brake-lube/
    I wont use any of it anymore after using sil glide but I understand ymmv
    1976 Yamaha XS 360
    Jun 27 2011
    In your experience I suppose. In my exprience it works just fine across 3 different cars (B6, B7, Q5). So does that mean my anecdotal evidence cancels out yours?? haha.
    But seriously, I'm not saying its the best, simple saying I've had good experiences with it. The Sil-Glide stuff sounds legit but since I already have my Permatex and its not let me down, I'll continue using it I guess.
    Although, I'm starting to mull over a 345mm Q5 front upgrade (fixed calipers FTW) so I'll likely not need it for those I guess...
    Edit: on the other hand, their ceramic greases definitely sound better. So, yea maybe don't bother with the green stuff unless you're on a budget. I don't think I saw the red or blue stuff when I got mine forever ago (2010 maybe?). Might be time to upgrade my grease after all, now that I'm realizing my jar is nearly a decade old. Damnit Iceman, you badgered me into buying more stuff!
    Also the second page of the PDF linked on that Permatex page is actually pretty concise and helpful in describing where to apply grease to caliper parts: https://441py33rout1ptjxn2lupv31-wpe...PS-FLYR-V4.pdf
    -CP
    2017 Q7 3.0t
    Jul 05 2016
    It's crazy how there doesn't seem to be a straightforward answer for this. I'd think that VAG would have a definite specification on what to use.
    Jun 27 2011
    ETKA lists Lithium Grease on the page with calipers, pads and rotors, FWIW.
    -CP
    2017 Q7 3.0t
    Jul 05 2016
    Oh nice. I don't have access to Etka. Good to know though.
    Jul 05 2016
    This is interesting.
    https://www.bobistheoilguy.com/forum...pics/4496766/1
    Sent from my SM-T380 using Audizine mobile app
    Jun 27 2011
    ELSAWIN states to use this stuff:
    Polycarbamide is Polyurea. So molykote or something should be what the factory specified.
    -CP
    2017 Q7 3.0t
    Jul 05 2016
    Item 1 (item 11 in my elsawin) in the accompanying diagram points just to the pads. "Pad guide surfaces" just sounds like the caliper/pad contact points, not the pins.
    For item 16 in the figure in that section, which are the guide pins, it just says "Guide pins, 30 Nm". No mention of lubrication.
    Jun 27 2011
    Yea I noticed no specific mention of lubing the pins. Obviously you need to, as there’s lube in there from the factory but no mention of what kind. I’d be inclined you use that same urea grease if you have some. That Honda stuff is probably better and cheaper than the VAG stuff.
    I know the stuff I’ve scraped out is grey, and a tad sticky. Not sure if it’s grey from wear or age but it is, FWIW.
    -CP
    2017 Q7 3.0t
