Results 1 to 15 of 15
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    ABS Module Repair?
    I know there was a member here that was doing it, but I don't remember who it was.
    I totaled my Avant on Friday and am looking for a replacement. I found one with really low miles, but the owner said that it has a permanent wheel speed sensor fault and the speedometer isn't working because of the abs module. I'd like to get an idea of what it will cost to repair so I can factor that into my negotiations.
    Any help will be greatly appreciated.
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    http://www.cheapabs.com/vraudi.html
    I believe it's around $120.00 but it looks like they might be down right now. Send them an email.
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by RDA990 View Post
    This
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Jan 04 2014
    US
    I had similar problem.
    I sent my old ABS ECU to repair
    Then come back to replace the new set of ABS module with the OLD ABS controller
    B6 04' A4 1.8TQ 6MT
    Aug 17 2015
    Evansville, IN
    OK, perfect. Thanks for the link.
    And if I'm not mistaken, these are the style that you can remove the module from the assembly and not have to break the brake system open to remove and send in, correct? And even possibly drive the car if need be with the module removed, right?
    Jul 14 2009
    Pasadena
    i sent mine to k0mpressed in b6 section i think he did them for everyone back in the day
    IG: @matthewee
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Quote Originally Posted by 16vCorey View Post
    With the module removed, the brakes still function but like a pre-ABS car, no anti-lock. But try disconnecting the ABS connector and see if the speedo works, which it should.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Yes, you can remove the electronics portion without disconnecting any lines. The car will still run, but you won't have ABS (hopefully this is obvious) and your speedometer will likely also be out
    Quote Originally Posted by Turbo510 View Post
    Speedometer would only work on the early 02 models that didn't use the wheel speed sensor I believe.
    Sent from my Pixel 3 XL
    Veteran Member Three Rings fabric8's Avatar
    May 14 2013
    US
    Quote Originally Posted by imnuts View Post
    This is correct because my speedo worked fine even when my ABS module died and I removed it for a few weeks while waiting for a replacement to be delivered. Ours is an 02.
    Sent from my SM-G950U using Tapatalk
    HIS - 2016 Golf R 6MT
    HERS - 2002 B6 A4 1.8TQM Avant | Motoza Stg.1.5 | OEM A6 4.2 17" forged fat fives
    Jun 29 2014
    America
    Another vouch for k0mpressed, Reflect Tuning is the company http://reflecttuning.com
    Aug 17 2015
    Evansville, IN
    k0mpressed is who I was thinking of. Thanks everyone!
    Jan 07 2013
    I contacted k0mpressed before anyone else, unfortunately he said he no longer fixes ABS modules. I'm not sure if that changed since I contacted him, but let us know how it goes.
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    ABS Module Repair?
    x2 what RDA990 said
    I contacted kompressed about a year ago asking about ABS module repair and he said he no longer does them. So unless something has changed since then, you’re better off going through cheap abs.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Aug 17 2015
    Evansville, IN
    Awesome. Thanks for the info!
    Jul 14 2009
    Pasadena
    http://www.cheapabs.com/contact.html
    sounds like they are not taking orders rn
    IG: @matthewee
