Results 1 to 2 of 2
    Sep 23 2019
    Sambo
    Gearbox malfunction + Parking brake malfunction
    Am getting a Parking brake malfunction followed by a Gearbox malfunction on my Audi A4 B8.
    The car drives well and also shifts gears when this error comes especially after driving and putting the car on park.
    Below are the error codes also attached
    Read Trouble Code
    No.
    ID
    DTC Info
    Status
    1
    DTC code
    System name/DTC content
    DTC status
    2
    03-Brakes 1
    3
    P091900
    Gear selector , malfunction
    4
    P150A00
    - Ignition switch off - Duration signal , Untrustworthy
    5
    05-Kessy
    6
    P070600
    Driving gear sensor , Untrusted signal
    7
    07-Display Control Unit
    8
    01315
    Transmission control unit - Please read DTC
    Passive/Sporadic
    9
    08-Air Conditioning
    10
    00473
    Electronic parking / Manual brake control unit -J540 - Please read DTC
    Passive/Sporadic
    11
    09-Central Electrics
    12
    00955
    key 1 - no or incorrect basic setting/adaptation
    Passive/Sporadic
    13
    03157
    Impaired function due to communication failure
    Passive/Sporadic
    14
    37-Navigation
    15
    01206
    - Ignition switch off - Duration signal - Implausible signal
    Passive/Sporadic
    16
    01315
    Passive/Sporadic
    17
    03280
    Headlight rotary switch position - Implausible signal
    Passive/Sporadic
    18
    47-Sound System
    19
    00862
    Navigation System (GPS) antenna - Open circuit
    Passive/Sporadic
    20
    02288
    Chip reader control unit - No signal/communication
    Passive/Sporadic
    21
    53-Parking Brake
    22
    02653
    Traffic data antenna - No signal/communication
    Passive/Sporadic
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I know this seems counter-intuitive, but you might have better luck in the B8 S4 section.
    The B8 A4 didn't come with the DTC transmission here in the US, but the S4 did. There are a handful of non-US members that post here, but you'll likely get a lot more input in the S4 section.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
