Yes, these are the correct dimensions. All Brake Performance parts are OE specs and fit.
Please see dimensions for both rotors #33146 & #33133...
FRONT ROTORS #33146:
TYPE Brake Discs
Outer Diameter mm 400
Outer Diameter inches 15.748
(s)olid / (v)ented V
Height mm 52.2
Height inches 2.055
Nominal Thickness mm 38
Nominal Thickness inches 1.496
Min. Thick mm (Discard) 35
Min. Thick inches (Discard) 1.378
Hub Hole/Whl Reg mm 68
Hub Hole/Whl Reg inches 2.677
Number of Studs 5
Mounting Type Floating
Bolt Circle Diameter mm 112
Bolt Circle Diameter inches 4.409
Bolt/Hole Dia mm or Stud Size 15.24
Bolt/Hole Dia in or Stud Size 0.6
Vane Style Curved
Weight (lbs) Including Box 32.95
REAR ROTORS #33133
TYPE Brake Discs
Outer Diameter mm 356
Outer Diameter inches 14.016
Height mm 36.1
Height inches 1.421
Nominal Thickness mm 21.8
Nominal Thickness inches 0.858
Min. Thick mm (Discard) 20
Min. Thick inches (Discard) 0.787
Number of Studs 5
Bolt/Hole Dia mm or Stud Size 15.3
Bolt/Hole Dia in or Stud Size 0.602
Vane Style Pillar
Weight (lbs) Including Box 18.30
