Results 1 to 21 of 21
    Junior Member Two Rings W3N's Avatar
    Mar 19 2019
    NY/PA
    Rear wheel leaning inwards at the top
    I recently found out the both of my rear wheels are leaning inwards at the top. The driver side rear wheel apparently leaning more compare to the passenger rear wheel. And I just have alignment done. It still leans inwards. What is exactly wrong with the rear wheel? Any ideas? IMG_0907.jpgIMG_0909.jpgIMG_0910.jpgIMG_0908.jpgIMG_0911.jpgIMG_0912.jpgIMG_0918.jpg
    Senior Member Two Rings shuzj944's Avatar
    Jul 24 2011
    B5 S4, C7.5 A6, B8 Q5
    Louisiana
    I'm going to go out on a limb and say theres nothing wrong....
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Let’s see the alignment printout...
    Mar 19 2019
    NY/PA
    Quote Originally Posted by bajan01 View Post
    I’m going find it and post it tomorrow
    Mar 19 2019
    NY/PA
    IMG_0924.jpg Here is the alignment printout
    Veteran Member Three Rings fromwrxto330ci's Avatar
    Feb 27 2007
    Sacramento
    My A7 is the same thing
    Instagram: @essj0n
    Senior Member Three Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    don't get fooled by the fender angle and look at your alignement sheet for the camber angle
    Sep 07 2019
    1.3 degrees is fine
    Nothing wrong
    Jun 09 2017
    Signature
    GTA
    Within spec so everything is fine, its just an optical thing.. Doesn't help that your tire is a bit stretched, sort of adding to the neg camber look.. The top of the wheels look like they are facing in because they are.. It's how performance suspension setting are set up..
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Senior Member Two Rings PeytonBrandt's Avatar
    Jun 10 2019
    Neenah, WI
    Negative camber is expected, especially for sportier cars. It helps with handling around corners.
    Like others have said, if it’s within spec, there’s nothing to worry about.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Your subframe could be slightly out of alignment. Not uncommon and most people don't notice it. My friend had this exact issue with his S4.
    Check out this thread that shows what a misalignment looks like: https://www.audizine.com/forum/showt...rame-Alignment
    2016 S6
    Jul 24 2019
    Chile/Antofagasta
    Hello
    I didn't want to start a whole new Post for this... so seeing you people seem to be able to correctly interpret this graphics i will give it a shot
    It happens that my car (2013 A6 C7 2.0TFSI) has the steering wheel a little tilted to the left, if i try to correct it it makes my car go a little to the right
    I got it aligned and it improved, but it felt like it wasn't perfect. Two weeks later it was the same as before the alignment...
    Do you think it is just a matter of re-aligning + rotating tires or do i need to get something else checked ?
    Mar 19 2019
    NY/PA
    Thanks for everyone who replied! I won’t worry about it too much. Might get some beefier tire, like 285/35/20. Currently running on 275/35/20 with a 10.5 inch wheel.
    Mar 19 2019
    NY/PA
    Quote Originally Posted by aldomejias View Post
    Hello
    That’s exact same thing happens to my car right now! I have no idea what is wrong with it. Just did alignment. And it still doing the same thing but it improved a little bit.
    Jul 24 2019
    Chile/Antofagasta
    mine improved, but short after it was just as before
    what i didn't do was tire rotation i have the left front tire unevenly wear in the center i think it has to do with this
    Mar 19 2019
    NY/PA
    Yeah I know right. There are just no sweet spots in the middle and Hope it works for you!
    Mar 30 2018
    long island
    Quote Originally Posted by W3N View Post
    at no time should the relationship of your steering wheel and direction that your car travels change over time, unless there is impact (severe pothole, accident, etc.).
    at time of alignment the tech should have straightened the steering wheel (prior to any adjustments), braced it, and then made all adjustments. if the wheel was not centered and braced properly, they alignment was done while your wheel was off center, and will (should) always be off center until it is realigned.
    bring it back to the shop if when holding your wheel centered does not direct your car straight.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Mar 19 2019
    NY/PA
    Quote Originally Posted by daytona rs7 View Post
    Thank you for your message. I’ll drive a couple more days see if it will improve by itself. If not I’ll take it back to the dealer and redo the alignment.
    Jul 24 2019
    Chile/Antofagasta
    thank you
    i will and will post back
    i'm thinking of taking it to another Shop
    Enviado desde mi SM-G975F mediante Tapatalk
    Mar 11 2018
    Severna Park, MD
    Mine are exactly the same and I'm in alignment. I try not to think about it.
    Veteran Member Three Rings infinitereality's Avatar
    Jul 05 2017
    Superlite Coupe (SLC) & CRF50
    Louisiana
    Hello
    Bushing is fixing to take a dump.
    2018 Camaro ZL1 - Black
    - OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
    - RotoFab, Forgestar CF5V ZLE offsets, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
    - Carbon Fiber: Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
    2019 Superlite Coupe: SLC IR/8 - Grigio Telesto
    - 525HP Crate LS3 & Graziano Transaxle
    - 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
