I’m going through the tuning process with Motoza for the F21 turbo. Long story short I keep getting these two codes that continually pop up. P0171 which is a lean fuel trim code and P1297 which is the pressure drop between the throttle body and turbo. I did end up changing the DV because the old one failed the vacuum test. The new DV did help and I’m boosting stronger. But like I said I keep getting the P0171 and P1297. When these codes pop up, the engine sort of goes into a limp mode where it won’t boost past 15psi. Normal boost is 22-23psi for me.
Now Motoza i feel they keep thinking the MAF sensor is to blame. The reason I think this is because they keep asking for logs with and without the MAF sensor connected.
Any thoughts/experiences?
Sent from my iPhone
