Results 1 to 18 of 18
    Senior Member Three Rings stevemiller333's Avatar
    Oct 22 2016
    05 B6 S4 SDN, E46 M3 VERT, 2018 F150
    Rochester, NY
    Driving without ABS Module is wierd.
    I pulled my ABS module last night to send out for repair. I have read that its totally fine to drive around without it so I thought I would give it a go.
    My car is totally different without the module.
    First of all, what is going on with the steering?! It is so light, it feels like a civic. It actually feels like I could push the car a little harder in the corners but it was so strange feeling I didn't mess with it.
    Moved to avoid a pothole at about 75 mph and almost shot off the road! I am guessing that the computer offers more steering assistance at low speeds and since it thinks I am not moving it has the power steering on max or something, maybe someone could explain.
    Secondly, clutch disengagement is 100% worse, especially when it is cold, and through first 3 gears. Press the clutch peddle down to shift to second and there is a pronounced THUD and it feels like the engine and tranny drop a few inches.
    So strange, normally shifts rock solid and so smooth. What the heck could this be?
    Throttle feels a little different too.
    Anyone have any science to explain? This module certainly does a lot more than ABS, I think I will take the other car to work for the next few days until I get it back fixed!
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    definitely!! It will also do the exact opposite on your symptoms.. it can have a hanging throttle between the shifts and the steering can feel like you lost your power steering.. I also didn't have a MPH reading. That module makes everything work in unison. Let me know if you have a coding issues once you install your fixed module..
    AM Tuned Supercharged Audi S4 Avant track car. Under Construction
    Tuned by Jackal Motorsports
    Time Attack driver
    jasons__s4 IG
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    I had many of those symptoms this summer during hot weather WITH the module still on and it would change from day to day. One day Honda Civic steering, one day old school truck steering. Usually no speedo. Hoping to get mine out this weekend. Did you have any trouble getting yours out?
    Oct 22 2016
    Rochester, NY
    Yea it makes the car very different. I am curious how it affects the steering so much. Check engine light was on today so I have the full light show going on now!
    Thanks Jds, I will reach out if there are coding issues when I get it back. I found this seller on Ebay and paid $120 for the fix. He has no items in his store as of today so I hope I didn't get hosed.
    https://feedback.ebay.com/ws/eBayISA...ab=AllFeedback
    I went with this seller because he has done a ton of them, has 100% positive feedback, and he doesn't fix it if it's not broken. He tests it first.
    It was a little more difficult to take out than I thought it would be, but it still only took a half hour or so, 1.5 beers. In a youtube video I watched the tech bend the unit right out of its cradle in one quick motion. This was not the case with me at all. I unclipped the brake lines from their plastic mounts near the unit so it had more give. I had to pull up on it harder than I really wanted, to get an angle on the lower 2 screws (bending brake lines) I would recommend having a long torx handled screw driver or a socket with a long shank. This helps in getting the lower screws out. I stuffed some plastic shopping bags in where it was. All of the lines bent back to their normal locations and looked good.
    Here is the form I had to fill out to send it in....
    http://www.cheapabs.com/ABSFORM.pdf
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    The ABS sensors are the car's speed sensors at the same time. Without the ABS module the car doesn't know how fast it travels.
    Most cars (not sure for S4) came with Audi's servotronic steering assistance which makes the steering lighter at low speed and tighter at high speed. Without the servotronic receiving a speed input from the ABS module it will affect it's behaviour.
    And in response any other auxiliary element requiring a speed input.
    The ABS sensor is located at the wheels (see bellow) and is simple proximity switch (encoder) counting the groves on the axle CV.
    Here you can see the groves on your axle CV which trigger the ABS sensor when the wheel is turning.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Aug 27 2016
    GL450, GLA250
    Quote Originally Posted by stevemiller333 View Post
    It was a little more difficult to take out than I thought it would be, but it still only took a half hour or so, 1.5 beers. In a youtube video I watched the tech bent the unit right out of its cradle in one quick motion. This was not the case with me at all. I unclipped the brake lines from their plastic mounts near the unit so it had more give. I had to pull up on it harder than I really wanted, to get an angle on the lower 2 screws (bending brake lines) I would recommend having a long torx handled screw driver or a socket with a long shank. This helps in getting the lower screws out. I stuffed some plastic shopping bags in where it was. All of the lines bent back to their normal locations and looked good.
    Since I am working on as much weight reduction as possible I went ahead and removed the windshield water reservoir to access those 2 lower torx without bending the lines too badly. During install I just left the two lower bolts out :)
    Aug 27 2016
    GL450, GLA250
    Quote Originally Posted by ven0m View Post
    I was going to check my abs/ speed sensors first but i noticed to even remove them I would have had to remove my whole setup (calipers, rotors, phaeton brake ducts) so I went a smarter route and performed the live data test which was much easier. The test will show that the sensors are working without the module coded.
    Oct 22 2016
    Rochester, NY
    "Servotronic Steering" That is what I was looking for! Going to do some research on how that works now.
    Thanks Venom. I know a lot of the newer cars have steering assistance for their electronic systems, but I didn't know Audi had one for the older hydraulic systems.
    So there must also be some sort of system that helps with smoother clutch disengagement under speed that doesn't occur at 0 mph.
    Aug 27 2016
    GL450, GLA250
    http://wiki.ross-tech.com/wiki/index...28Bosch_5.7%29
    Use this for your coding. Look in your car service manual to confirm your brake setup but I’m sure it will say 1LJ for brembo brakes. After your soft coding you might possibly show that steering is “locked” via VCDS but just read the special note at the bottom of that link and just follow the instructions. You don’t necessarily need to perform the steering test since that just involves you driving around the block for a few minutes with a few full turns
    Oct 22 2016
    Rochester, NY
    Quote Originally Posted by Jdsb6s4 View Post
    Do you think I will need to recode the module if I am reinstalling the same module?
    - - - Updated - - -
    Also, thanks for that, now I understand the coding.
    Aug 27 2016
    GL450, GLA250
    - - - Updated - - -
    I am going to say yes because I got that “locked” reading and couldn’t figure it out so I tried to put the old one back in and it needed recoding.
    Jun 09 2014
    BMW E28 with S54 Swap, rack and pinion conversion, vacuum brake conversion
    Jacksonville,FL Lincolnton,GA
    What do the different brake setup codes do to the ABS module? Is this something that should be recoded if you install a BBK?
    May 10 2015
    Slovenia
    Depending on the sensor type you can also check them at the connector/cable by measuring the contacts. Not sure which sensor we are utilising on the B7, but these would be your measuring points with a simple multi-meter.
    The clutch would be a strange one as it is linked to the same hydraulics as the brakes. The brake accelerator should be independent of car speed normally, but given how z-germanz like to over-engineer everything, might very well be possible.
    James May: "Yes."
    Jul 01 2013
    Anchorage, AK
    Thanks OP for removal experience report. Does anyone know if a V Checker tool is adequate for coding the module? I don't have VCDS.
    Aug 27 2016
    GL450, GLA250
    Quote Originally Posted by ottocycle View Post
    you just need to lock in the appropriate code for what your car is and has. No it does not need to be recoded when you install BBK. I am running 18z and my car is fine.
    Time Attack driver
    jasons__s4 IG
    Oct 22 2016
    Rochester, NY
    All fixed! No lights and everything is back to normal. Also, coding was not needed.
    Aug 27 2016
    GL450, GLA250
    oh thats sweet.. I must have needed to recode since I put in a different one... good stuff!... now get out there and break something else ;)~
    Time Attack driver
    jasons__s4 IG
    Oct 22 2016
    Rochester, NY
    Thanks for all your help, on to the upper control arms and oil filter housing leak! Trying to get some issues resolved before winter.
