Results 1 to 40 of 46
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Supercharger belt slip? And how to eliminate
    About 5k miles after I changed my lower pulley on a hot day I noticed my supercharger pitch not climbing as it should. I can't think of anything but belt slip that would cause my blower to spin more slowly than it should.
    https://youtu.be/_L9Z5EcMe5g
    I have a correctly sized belt and good tension on it but this is still occurring. I'm boosting about 4psi less than I should be. Tends to happen more on hot days after driving for a whole when my engine bay is heat soaked.
    Can anyone confirm that this is indeed belt slip? And how to fix it. I've heard CTS upper pulleys slip?
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    What pulley size(s) and what belt size? 6 rib or 7 rib belt? Also what brand belt?
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by bajan01 View Post
    Gates 7pk 1325 with a 57/196.5
    Didn't slip a bit for the first several thousand miles. I guess once it slips once it glazes the rubber causing more and more slip. So I think the belt is done (if this is indeed slip)
    I have a contitech 7pk1335 waiting to be put on to see if it will rectify the issue
    Sep 10 2012
    London
    Is it a gates performance rpm belt?
    If not, get one from Issem.
    Jan 11 2018
    Florida
    Quote Originally Posted by Morritse View Post
    I think that 1335 will be too big (loose). I run a 1338 on my 57/203 setup. Check the underside of the belt and see if the ribs are breaking up.
    May 08 2018
    Berkeley, CA
    They appear to be in good condition visibly but there's quite a bit of black rubbery debris that comes off when I run it.
    Jan 11 2018
    Florida
    Sounds like that belt is falling apart. I always buy two at a time but mine have been holding up well.
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Probably not your issue but I’ll throw it in. I had the same issue when I was having intake flap issues. Do you have loss of power as well?
    Doesn’t look like it based on video but figured I’d ask. I know you know a lot about these cars so disregard if there is no loss of power.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Whitee View Post
    Loss of power due to less boost. It pretty much feels like I have 4PSI less of boost. Nothing extremely drastic. I don't have any codes, I recall you having them right?
    Jan 11 2018
    Florida
    Log it and see where your boost is compared to before.
    May 08 2018
    Berkeley, CA
    Its at 17 compared to 21 before.
    Jan 11 2018
    Florida
    Yeah it certainly appears that the belt is slipping. I think that P3U had a similar issue a while back which turned out to be a disintegrating belt.
    May 08 2018
    Berkeley, CA
    I'm just wondering what caused it. Once it starts it makes sense that it will create a positive feedback loop, but the belt only had maybe 7k miles when it started. Maybe it got some coolant or oil on it which started the vicious cycle?
    Anyways. I talked to issam. They're coming out with a gates RPM 1325 belt soon, so I ordered a bando one which will hopefully hold up until then.
    Jan 11 2018
    Florida
    I believe that the extra rpm kills the belts because ultimately you have a bit of slippage and it simply gets worse over time.
    What tune are you running and has anything changed recently tune-wise?
    May 08 2018
    Berkeley, CA
    Nothing changing tune wise. It started when I moved from 80° to 110° weather. Probably didn't help it.
    Feb 14 2018
    Sydney,Australia
    I run the same pulley sizes 57/196.5 and use gates rpm 1310 from issam.No belt slip.1325 belt from exelarate performance was slipping and showed the same symptoms.black fine debris as it started to wear in.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    New belt probably fixes the problem, but maybe the tensioner spring is weaker than you realize. They are pretty inexpensive. Might want to replace it while you have the belt off. Only one center bolt to remove to get it off. I don’t recall if the bolt is too long to get out without service position.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Black s5 View Post
    Thanks for helping me confirm. The 1325 felt super tight honestly, how did you manage to get a 1310 on there
    Jan 11 2018
    Florida
    Lots of muscles and sliding the belt on to the tensioner pulley last as it doesn’t have a lip. I do have to say that the 1310 has to be super tight as I ran that on my 57/183 setup and thought that it was tight for that.
    Deactivated Four Rings
    Jun 23 2011
    The Gates RPM 7PK1300 works on the 183mm crank pulley and have a lot of people also use them with a 187mm, so the Gates 7PK1310 could work on a 196.5. Tighter is better than looser.
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    Hey did you move to the Phoenix area?
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by vpls4 View Post
    No, school in bay area > live in Central cal :(
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Hey man, I feel your pain. I bought my ported blower from a member here that sold his car and had a CTS pulley. At first seemed ok but after a few thousand miles I'd get belt slip and loss of boost, ask Ro. In the last year I've gone thru probably six belts, long story short, get rid of that POS pulley. I just went to 034 yesterday and had mine swapped, guess what, no more slip and gain my boost back .
    I had two Bando belts that it chewed it up (posted pic on thread for belts), went thru several Gates 7PK1325 Horizon same result were it was cutting them in between ridges (look for a faint white line). Glad I got rid of it.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Sep 10 2012
    London
    In case anyone isn’t clear, there’s a difference between the gates belt and the gates rpm belt.
    Normal gates belts are common place for many applications and are no good for our application. The rpm versions are a completely different animal.
    Dec 29 2011
    The Bay
    ^^ True but Gates RPM belts are not available for 7PK1325 hence why we run the Gates Horizon from your neck of the woods .
    https://assets.gates.com/content/dam...t-newbrand.pdf
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by RWD2quattro View Post
    I am wondering if it's more that there aren't any high performance belts made in the 1325 size. I never had a problem with my upper pulley when I was on a 179/187mm crank with RPM belts.
    Dec 29 2011
    The Bay
    I went DP (194mm) at 45k and I already had 034 upper pulley. The Gates Horizon (EPDM) 7PK1325 belt came from Issam with his crank pulley.
    I put 45k miles on that belt with no slip. At around 90k miles installed the ported blower with CTS pulley and had nothing but slip/chewing belt issues and that has been my experience and was the only thing that changed on my car belt related. From what the belts show (forensics), you can say, one of the ridges on pulley wasn't cut properly (tolerance) and too high as it was shinier and cutting belts in between ridges heating the belt and causing screeching/slip and fast deterioration. My car has 101k now and glad I got rid of that pulley, dealt with it for 10k miles. Please remove and inspect your belt thoroughly for these signs. Good luck with whatever you decide to do, just trying to help you.
    I have a spare 034 upper pulley on my stock charger still, I can let you to test it out, if I'm wrong, keep the pulley.
    Belt info.
    May 08 2018
    Berkeley, CA
    Belt info.
    Well damn. I'm down to buy it from you. Give it to Ro or something I'll pick it up from him haha
    Dec 29 2011
    The Bay
    Does anyone have a pulley puller I can borrow to help a brotha out?
    Sep 10 2012
    London
    Think there’s a 7PK1325 gates rpm on the way. I’m waiting for one.
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Adamantium View Post
    Ya. He told me April ETA
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Yes, I did have soft codes. Used a bottle of that miracle spray and everything cleared right up.
    Jan 11 2018
    Florida
    So I’ve been doing some reading...
    The Gates RPM belts are designed to stretch less than the standard Gates belts and therefore you will tend to see higher boost levels when using them under the same conditions as if you used a standard Gates belt.
    Having said that, they are more brittle than the standard belts and may actually be prone to breaking more than a standard Gates belt.
    I am currently using a standard Gates 7PK1338 belt with my 57/203 setup and all seems well. I am seeing 24psi on my analog boost gauge. I don’t seem to be seeing any stretch with the belt even though it should stretch more than the RPM belt. Maybe this is because it’s on very tight...I don’t know. The recommended belt for this setup is 1345 but I started with a 1340 and ended up at 1338. I don’t think that I have more than 5k miles on any belt yet as I have gone from bone stock to software only, to single pulley, to dual pulley, to bigger dual pulley, to finally 57/203, within 18 months...all of which have required a new belt. I am approaching 5k on this current belt (Gates 7PK1338) and it’s holding up well.
    Remember too that with a high pulley ratio you will be spinning the belt faster and any slippage will be magnified. All of this theory of stretch vs. minimal stretch goes out the window on worn belts, misaligned pulleys, poorly manufactured pulleys, etc.
    May 08 2018
    Berkeley, CA
    Ah so the crc GDI actually worked?
    May 08 2018
    Berkeley, CA
    I don't see why belt stretch would cause a difference in boost. No matter how long the belt is you're still get 3.x revolutions of the SC pulley per revolution of the CP
    Jan 11 2018
    Florida
    If it stretches and that stretch induces slip it would. This could also cause premature wear on the belt and the slippage would only get worse.
    May 08 2018
    Berkeley, CA
    Ok I understand. BTW any way to tell you have misaligned pulleys other than "looking"?
    Jan 11 2018
    Florida
    Ok I understand.
    I’m just speculating here. There are so many pr combinations using different pulley vendors, different ECU and TCU tune vendors that it’s difficult to pinpoint the root cause of some of these issues.
    For example, I had an interesting phenomena that would occur right at 5k rpm with my old tune. Everything pointed at temporary belt slip as I could feel less acceleration and then a surge right at 5k rpm. The belt was fairly new and on inspection all of the ribs looked good. I switched vendors and the problem went away, running the same belt. Acceleration is most certainly better having not touched the belt or tensioner.
    Jan 11 2018
    Florida
    I don’t know. I installed my pulleys and belts myself and I am confident that they are installed correctly and therefore should be aligned if manufactured to spec. I’m running an EPL upper pulley an iAbed Fluidampr crank pulley and ring. Zero problems from day one. I have heard of others having belts jump with similar setup but unless they somehow received a poorly manufactured pulley (hard to believe as these are not hand turned and there is quality control that goes into the process) the installation process or a bad belt would be the only other contributing factor.
    May 08 2018
    Berkeley, CA
    Going off what RWD said, I do believe him when he said his upper pulley is bad. The shiny ridge in combination with going through 6 belts a year with the only change being the upper pulley is quite convincing.
