Results 1 to 4 of 4
    Junior Member One Ring
    Apr 27 2018
    2014 Audi RS5
    Coconut Creek, FL
    Dead Battery 2014 RS5
    Good Morning,
    I am newer to the RS5 platform as I just got out of a 997 so I am still learning about the RS5. This morning I was excited to find my battery appears to be dead on my 2014 RS5. Before I purchase a new battery is there anything the dealer needs to do once I switch out the battery? I was thinking about attaching a tender to the terminals to keep power and just switch out the batteries.
    Also if anyone has any thoughts on what battery to use that would be great.
    Thanks
    Mar 15 2017
    Austin TX
    My 2014 just dies and replaced with this super light weight Anti-Gravity - need the 40ah version (they just came out with 60ah too but shouldnt be necessary):
    https://antigravitybatteries.com/pro...tive/ag-h6-rs/
    Use Promo code "fanpower" for a $100 discount if it's still working. My tech was able to swap it out in my garage easily, though it's a lot smaller than the oem one.
    Apr 27 2018
    2014 Audi RS5
    Coconut Creek, FL
    Thanks AsherAudi. I thought the Bosch batteries I have been buying for the 997 were expensive, boy was I wrong. The Antigravity battery must be amazing for that price!
    Mar 15 2017
    Austin TX
    Quote Originally Posted by TECN0 View Post
    Its top of the line and MUCH cheaper than the competitor Lithium Ion which sells for like $2500. The 40ah version weighs 11.5lbs so you achieve a 35lb weight savings in the process and the built-in re-start jump start feature is pretty cool. You can always go with an OEM battery for less but this is the perfect time for you to upgrade and shave a little weight :)
