Results 1 to 19 of 19
    Nov 08 2017
    Washington, DC
    RS7 sport exhaust on A7?
    Good day! Does anyone know if a pre-facelift RS7 exhaust will fit on a pre-facelift A7? My research says yes but just wanted to make sure. Anyone with insight on the sound it might produce?
    Many thanks!
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by seemonkey10 View Post
    Many thanks!
    Are you referring to the whole catback exhaust or just the rear mufflers? The rear mufflers in rs7 has no real tips. It's just two raw pipes coming back out of the mufflers into the rear diffuser. The rs7 has oval "tips" built into the rear diffuser.
    Why not just a rear muffler or suit case delete?
    Sent from my SM-G965U using Tapatalk
    Feb 09 2019
    Los angeles
    Many thanks!
    did it, very very raspy for my liking. mine didnt bolt on 100% we had to make a stepup from 2.25" piping because of the piping size difference but its very easy to do.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by Jivoz123 View Post
    Did you have to get tips for your RS mufflers? And also a different rear diffuser?
    Feb 09 2019
    Los angeles
    Quote Originally Posted by mintytoo View Post
    my cars a c7.5 so i fed the tips through the stock trim bezel thing. just bent them a little bit. but its very easy to change the tips
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Do you have a pic of the back of your car? With the new exhaust?
    Feb 09 2019
    Los angeles
    i switched the setup a few months ago i didnt like how it sounded
    now im running a
    s4 muffler thats gutted
    rs7 resonator
    baby resonators replaced with a custom xpipe
    Nov 08 2017
    Washington, DC
    Nov 08 2017
    Washington, DC
    The entire catback exhaust. Im wondering if the sound will change (less raspy) with just swapping the mufflers. I was also considering the center resonator delete/x-pipe mode but heard some negative reviews. Had anyone done it?
    Nov 08 2017
    Washington, DC
    Do you have a tune on your car?
    Feb 09 2019
    Los angeles
    no, i recently went stage 1.
    Nov 08 2017
    Washington, DC
    Has anyone heard of/tried these?
    https://topspeedauto.com/audi-a7-3-0...ks-conversion/
    Cars in the video clips have much better sounding exhaust than OEM and description claims performance gains.
    Feb 04 2012
    Poland
    Now I have catless header and stock A7 exhaust.
    Probably on the next week we try to install RS7 exhaust with MG resonated X-pipe instead suitcase resonator and remote controlled rear exhaust flaps.
    Nov 08 2017
    Washington, DC
    Quote Originally Posted by Lukas G View Post
    Keep us updated!
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    Keep us updated.
    This is the stock rs7 exhaust from what MY RS7?
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Feb 04 2012
    Poland
    Quote Originally Posted by DocTJ View Post
    Keep us updated.
    This one is 2017 but all RS7 exhaust are the same, no diffrence between MY14 or MY18
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    Any updates? I’m doing this on my A6 Monday
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Veteran Member Three Rings thorlax240's Avatar
    Jun 27 2017
    Boston, MA
    Reviving thread for more feedback.
    C7 Glacier S6 APR STG2 | APR dp's | AWE touring | Roc Euro | Eurocode F&R sways | 20" RS7 forged | 20" OEM rotors | -17mm VCDS | 15% Luminex | RS6 grill | transmission/differential inserts
    C7.5 Mythos A6 APR STG2 ECU+TCU | Single Pulley | Injen Intake | Eurocode F&R sways | H&R Springs | 17.5mm + 20mm spacers | 35% Luminex | transmission/differential inserts
    Mar 23 2019
    KS
    Sell the A7. Buy a car with 2 more cylinders. Thank me later.
