I have been dealing with this for almost a year and am ready to get it 100% taken care of. I did the mechatronic repair kit. It certainly changed when the car lunges but did not fix it. Before I did the repair kit, I never actually lost reverse.
I finally got a code that will hopefully point me to either replace the clutch packs or mechatronic. With all of the research I've done, it could be either-or. The dealer just replaces the entire transmission, so they are no help. Can anyone help so I don't have to guess at which to replace?
On to the code:
Code:
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb Part No SW: 4G1 927 156 S HW: 0B5 927 156 J Component: 0B5 40TFSINAR H01 0010 Revision: --H01--- Coding: 000001 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_TCMDL501021 001015 ROD: EV_TCMDL501021.rod VCID: 3D273B00ADFD700FE1F-8068 1 Fault Found: 18766 - Valve 3 in Transmission Part 2 P17D5 00 [096] - Mechanical Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 154090 km Date: 2019.09.07 Time: 23:38:19 Engine speed: 634 /min Transmission input speed: 634 /min Transmission output speed: 2 /min Engine torque: 24 Nm Transmission fluid temperature: 80 °C Accelerator position: 4.8 % Clutch status: Beide Kupplungen offen Unlearning counter according OBD: 40 Voltage terminal 30: 14.300 V
