Page 1 of 3 123 LastLast
Results 1 to 40 of 91
    May 01 2018
    Virginia
    Who's Running a TTE700?
    Just ordered my TTE700, and curious to get some reviews about it. I want a high 9 sec car so i think this will be good for me. And i will build the motor eventually... Just wanted to know some input from anyone running it!
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Who is going to provide your tuning? I think Brian from Unitronic tested this turbo on his car, maybe he can chime in.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Veteran Member Three Rings ChanceA4Parks's Avatar
    Jan 22 2018
    Ridgeland, MS 39157
    I'm running TTE780+ Turbos and they are monstrous. Dave at Motoza is handling the tuning.
    Sent from my SM-N950U using Audizine mobile app
    Only owned 1 Audi so far.....It won't be my last!!!
    Built 2008 Audi RS4 with a 2.7t swap. JE Pistons (9.0:1 83mm)and Pauter Rods. 2.8 heads with Supertech Valvetrain (stock size) and RS4 Cams. TTE780+ turbos, RS6 Throttle Body, Snow Performance Stage 2 Meth Injection, and Motoza Tuned. The Tuner Inlets and intercooling piping. ID1000 Injectors and 034 Surge tank. Just use your imagination on everything else!!!
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Most upgraded turbos with a basic map that ramps in torque properly will run high 9s. I know the SRM turbos on a lower setting run in the 9.6-9.7 range.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    May 01 2018
    Virginia
    Quote Originally Posted by S3DUDE View Post
    Unitronic Stage 3!!!! He was the inspiration for my upgrade!
    Jan 22 2018
    Ridgeland, MS 39157
    Here's you a video from my rebuild in progress, first start with TTE780+ turbos.
    https://youtu.be/AzlxVoHiOuQ
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by Eat.Sleep.Race View Post
    Are you Garrett?
    I sent you a WhatsApp message back the other day.
    I have the TTE700 on my car. Unitronic tuned and it's fantastic. Super smooth with a ton of power. TQ kept low for stock motor right now.
    If you come up to MD I can give you a ride.
    May 08 2015
    uu
    just wait for the tte777
    Sep 13 2018
    Jerseylicious
    Quote Originally Posted by Evilevo View Post
    Are you Garrett?
    What are the supporting mods and gas used on your build?
    Active Member Three Rings SlowSedans's Avatar
    Oct 27 2018
    R8, RS4, RS3, S4 x 5
    Tahoe
    Quote Originally Posted by ChanceA4Parks View Post
    Turbos? Motoza doesnt tune the Daza.
    Do you have a b5 s4?
    My posts are regularly edited or deleted, since 2004 because I tell consumers the truth about modifications or components from within the industry.
    Wastegate Rattle Fix info
    2017 rs3 nardo stage 2+
    2009 r8 phantom black & boosted
    2007 rs4 sprint blue snow car
    2000 s4 single turbo scary fast
    2001 s4 stage 3 street beater
    May 26 2008
    MD
    Quote Originally Posted by thejerseydon View Post
    Iroz DP, AWE SwitchPath, STM intercooler, Uni 4" Inlet, APR 4" pipe to stock airbox, TTE700, Uni Injectors, Uni Stage 3 ECU and Stage 3 TCU.
    I run the car on both 93 and E85
    Sent from my Pixel 3 using Tapatalk
    Sep 13 2018
    Jerseylicious
    Nice setup, im more focused on pump gas for now as nothing really close on the E85. low TQ map is that only for E85?
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    STM DP, STM intercooler, APR 4" Inlet, APR 4" pipe to stock airbox, TTE700, Uni Injectors, Uni Stage 2+ ECU and Stage 3 TCU.
    Not a fan of the two bolt STM DP flange.
    Brian and Uni are great.
    I love the TTE 700 whistle.
    I run the car on E85. Averaging 17mpg. Lots of in town driving. I get 20mpg highway.
    It is so subdued and quiet in comfort mode. Lots of power when you want it. I have not played that much and not ready to give a full review.
    Went from stage 2 93 uni file. The wastegate rattle with the tte 700 is significantly less, but still present. I’m not embarrassed to cold start my car in public anymore.
    I need to learn to log and make sure everything is running in an optimal fashion.
    If I had to do it again, I would go stage 2 ethanol until I was ready to build the bottom end.
    Also upgraded to Neuspeed RSE102’s with 255 Michelin ps4’s. I really like this wheel setup. Car feels so solid. Paul from Supreme hooked me up with the wheels and Brian Saxon sold me the tires.
    2018 Daytona Grey Audi RS3 - Unitronic tuned ECU/TCU - TC800XT built block - STM Intercooler & Downpipe - Unitronic Intake - After 14 months, alive again!
    2015 Deep Black Pearl VW Golf R - Stage 1+ - SOLD
    2012 Shadow Blue VW GTI - K04 - SOLD
    May 01 2018
    Virginia
    Quote Originally Posted by HWCN View Post
    Nice! I have similar wheel and tire setup also!
    - - - Updated - - -
    Are you Garrett?
    Yeah man! I need to come by and get a quick ride!!
    Sep 13 2018
    Jerseylicious
    Why?
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Why?
    More options, can go either hybrid of big turbo.
    Because I’m going to want more and I should have just done it all at once.
    Sep 13 2018
    Jerseylicious
    Makes sense I also hate wasting $ twice. Comments like yours are always appreciated. I think in end it depends where you want your power level at is 600hp enough if not bite the bullet and go all in BT and engine build. saves $ in the end. I think for me 600hp mid 10s car on pump is insane for the roads im on.
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    I could be wrong, but it appears u can get very close to the same torque on stock turbo stage 2 ethanol as with a hybrid w/o the bottom end build. The hp #’s are higher though. I think the logical progression is to stage 2 ethanol and enjoy, than build the bottom end and decide how far u want to go. Stage 2 ethanol is a lot of bang for the buck. Going hybrid/BT is a much greater $ commitment and if your willing to do it, you might as well do it right, hence why I wish I had built the bottom end.
    My progression from stage 1+, to stage 2, to stage 2+ is been far from cost effective and a bit tumultuous. I wish I had tried stage 2 ethanol before going hybrid. It may have been enough for a while, but once u start, it’s never enough. I think we are akin to crackheads, always craving more!
    Also, I rode in Saxon’s car which is tte700 on a higher torque file with a built bottom end and it’s intoxicating. I think since then he has pushed even further with some fueling updates.
    Just my thoughts. Eventually I’ll have a $100,000 in a car worth maybe $30,000. It’s the addiction thing.
    Feb 09 2016
    co
    Not just about the power and times, you also want to consider the street-ability of big turbo cars.
    To me stock turbo already feels laggy sometimes, i can't imagine driving on the streets with a big turbo car. Unless you're constantly going to be at 4k rpm i think the most i'd ever go is hybrid.
    Established Member Two Rings Audi TTRS's Avatar
    Jan 17 2019
    Quote Originally Posted by LJS5 View Post
    Same here, I'm costing out a hybrid setup right now. Rods and pistons, but stock clutches. The issue is that are no tunes on the market yet. You cant just go to a website of your tuner of choice and select your hybrid tune that matches your mods.
    2018 TTRS, APR intake/inlet, IE catted DP, APR intercooler. E85
    Oct 17 2018
    Idaho
    When do you foresee the rs3 being worth 30k? Where was your expense higher due to going from 1+ to 2? In reality the only part you didn’t need is the secondary down pipes?
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Subscribed. Interested in the SRM or TTE700 hybrid setup. Curious about longevity of stock internals on 600+ hp.
    Also curious about drivability on a hybrid setup (i daily my car in the summer).
    Are those on hybrid setups now running upgraded in-tank fuel pumps?
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Quote Originally Posted by MichiganRS3 View Post
    On Uni tune, TTE 700 daily driving is great!
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Quote Originally Posted by DarthVaderIX View Post
    My point is the expense coupled with the depreciation are enormous, but within 5 years when the car has a 100,000 miles, 30k will be a stretch.
    Every tuning upgrade, travel time, 2 different inlets, labor costs, my time all are reasons why it was not a cost effective journey. My point is that going straight to stage 2 is more cost effective, and I believe the best bang for the buck. My Uni stage 2 tune was great. I never tried the ethanol file which in retrospect, I wish I had.
    Your journey and opinion may be different. I’m just sharing mine.
    Oct 17 2018
    Idaho
    I appreciate the perspective. I am doing my best to not re do things, like I’ve done repeatedly in the past on cars. I think 1+e85 with supporting mods that would/will transfer over to a BT when the time comes
    Sep 13 2018
    Jerseylicious
    From what i understand and have seen online even BT spool at 3500 so like stock. I do agree the DD you feels laggy but it is what it is with this car.
    See here is the issue with some us with hard to get E85 going STG 2 without E85 is a very small gain so not a great option.
    Again its people like you pave the way and help answer questions so thanks.
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    TTE700 is a great all around turbo!
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Jan 22 2018
    Ridgeland, MS 39157
    I do not have a b5 s4. I have a B7 a4 that I'm converting to an RS4 and I've already completed the b5 2.7t swap. Does this count?
    Quote Originally Posted by SlowSedans View Post
    Aug 17 2019
    Sunshine State
    Is it really worth risking a TTE700 on a stock engine though?
    Apr 22 2012
    Norway
    Quote Originally Posted by Brian@Unitronic View Post
    Will there be a tte700 upgrade with stock cat available with reduced HP from unitronic?
    Sent from my iPhone
    Apr 10 2019
    2018 TTRS Stage 3, 2016 TT Roadster Stage 2+, X5 35d Stage 2, 335d Stage 2
    Harrisburg, NC
    I am very close to buying this turbo. I am having my motor built next week and I am just trying to make a final decision on a turbo. The TTE700 seems to be a great candidate as it spools really well and make good power up top. I don't believe that I have seen any TTRS with a built motor using this turbo. I suspect that it should be good for 145 trap speeds at full weight in the TTRS.
    Jun 02 2018
    Blackpool
    https://youtu.be/EatwZ9_4WnA
    Non built motor so you should see more torque on a built motor.
    https://youtu.be/OhFo1mYeBNg
    https://youtu.be/pK8tH7MMcgs
    And a rs3 on srmotorsport turbo https://youtu.be/QMX50nMGi1Y
    Hope these help abit.
    Apr 10 2019
    Harrisburg, NC
    I bought the TTE700 today and I will post some results once I get my car back from a motor build. Unitronic is tuning my car.
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    I run the SRM/EC on mine. 10.2 @140 full weight, street tire.
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Oct 07 2008
    Earth
    Quote Originally Posted by Kai@EliteMS View Post
    Stock motor? How many miles?
    May 01 2018
    Virginia
    Quote Originally Posted by lamboworld View Post
    Nice man! Gonna be a good fall!
    Mar 22 2011
    Quote Originally Posted by purekoryo View Post
    Stock motor, 9k miles on this setup no issues.
    ELITE MOTORSPORTS
    P: 631.775.6634
    Veteran Member Four Rings 1FastS4.Com's Avatar
    Feb 19 2004
    Tesla Y Performance and Audi TTRS
    Mine was at 11k miles all hard and had no issues. Same setup as Kai. Only building motor to push it harder.
    || 2017 Audi RS3 || 2018 Tesla P3 ||
    May 01 2018
    Virginia
    Good to hear so much good turbo systems performing well on stock motor!!
    Feb 15 2015
    2019 Audi Q7
    Minneapolis, MN
    What made you guys go with the stock airbox verse apr intake? Looking to do a build so looking for feedback. I typically don’t like open filter design so will probably do the same thing you guys did with 4” inlet to stock intake
