Results 1 to 9 of 9
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Another Rear Endlink Option: Ultra-Power?
    Was scrolling through RockAuto this morning, about to order some Moog endlinks for my upcoming swaybar installation (Eurocode) and saw another set of metal endlinks for the rear, which have a bushing pre-pressed in.
    Last time I Installed a set of Moog rear endlinks the bushings supplied compressed and deformed quite a bit in order to completely tighten the bolt that threads into the control arm. Other than that the endlinks worked great, just couldnt help but wonder why they installed that way.
    Thoughts on these? Anyone ever hear of this brand?
    https://www.rockauto.com/en/catalog/...+bar+link,7580
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jul 31 2016
    PA
    They definitely look like a Moog copy, I do like that they use bonded rubber bushings instead of the poly like the Moogs though. I just wonder what metal that is and how well it would hold up to salt, etc. Especially if it is just a plating, it may chip off and rust with road debris, etc. Without more details can't be sure though.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Jan 20 2014
    Calgary, AB
    I think I am going to give them a shot.
    I might experiment a little and throw a coat of paint on them, a set is $35CDN shipped from RockAuto...about half what Moogs cost.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by SDV325 View Post
    Let us know what you think. My 034's are still fine, but when they wear out, these might fit the bill for me.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I would think the poly bushings (Moog) would be firmer (more control) and last longer than rubber.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 31 2016
    PA
    He stated the same problem I had with them though, they really don't line up right and the bushings get twisted trying to fit them in. Could just be because of the 034 bar and they could be fine with the stock one. Can't hurt to try them and 35 bucks a pair.
    Jan 20 2014
    Calgary, AB
    Exactly, if the Moog bushing deforms and compressing during installation of the bolt, what is it doing when realistic driving conditions are thrown at it with the entire weight of the vehicle in play...
    Feb 14 2017
    Gulfport, MS
    Your thinking makes sense. But, I’ve universally had sloppy handling with rubber bushings compared to poly on other vehicles, so I’m conflicted. I guess there is only one way to know.
    I’m still stock at 50,000 miles, so my day is coming.
    I know that end links suspension bushings should ordinarily be very liberally greased when installing the bolt. Are you guys greasing them well? Many of the Moog Problem Solver end links on other applications come with zerk grease fittings for that reason. These don’t.
    But, end links, regardless of brand, will still need grease.
    Jul 31 2016
    PA
    I even added zerk fittings to mine in anticipation of that and I greased everything liberally before installing, for me and the 034 rear bar, they just really didn't fit without having to force it and I wasn't comfortable installing them. The stock ones went right back in perfectly. I don't really know why, they should be the same as far as bolting goes. Again my guess is it is just where the mounting holes are are different enough, but don't know for sure.
