I bought a 2011 Q5 with a 2.0 L turbocharged 4 cyclinder (CAEB) where the timing chain had slipped and the valves were all bent. I replaced the head, valves, cams, pistons, con rods, timing chains and slides, oil pump and all seals. The engine runs great after I re-installed it, but it leaks heavily out both main seals when I rev the engine. Low leak at at stead revs. When I take off the oil filler cap, there is a good vacuum in the crankcase, felt holding my hand over the opening. I took off the front pulley and polished the seal seat area to remove the very slight groove there but it still leaks. Though there is no noise or rattle, I'm guessing this may mean a slightly bent crankshaft that vibrates slightly when rev'ed, sufficient to allow oil past the main seals. I have also ordered a new PCV valve in case its crankcase pressure related, but the old one looks good - no rips or obvious leaks and no engine codes thrown. Is there any other possibilities I am missing that could cause this? How likely is it to have a bent crankshaft from the pistons hititing the valves?
