Results 1 to 19 of 19
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Speed by Gear by RPM Chart
    Anyone have a speed by gear by rpm chart for the RS3 with stock size tires?
    Thanks.
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    Senior Member Two Rings RSKYBET's Avatar
    Jan 16 2018
    Midwest
    I had to make a calculator in Excel from scratch because of the two different final drives.
    I can try to post a screenshot later this evening when I get home.
    2017 Audi RS3 1 of 244 (250) and 1 of 33 in Mythos Black
    @surprs3
    Apr 30 2015
    Michigan
    Quote Originally Posted by RSKYBET View Post
    That'd be great.
    Curious - what were the 2 final drive options?
    Asked differently, what option would change the final drive ratio?
    Jan 16 2018
    Midwest
    Quote Originally Posted by MichiganRS3 View Post
    That'd be great.
    There aren’t final drive options per say, the gearbox actually uses a different final drive internally depending upon the gear you are in.
    @surprs3
    Jul 13 2018
    Winnipeg, MB, Canada
    Gears 1, 4, 5 and R use a 4.06 final drive. Gears 2, 3, 6 and 7 use a 3.45.
    2018 Audi RS3 - Ara Blue, Black Optics
    2019 Audi SQ5 - Manhattan Grey, Black Optics
    Apr 30 2015
    Michigan
    Well, today I learned.
    Good info! Thank you.
    Jan 16 2018
    Midwest
    @surprs3
    Apr 04 2012
    2019 RS3 Ara Blu
    So our goal should be getting to 230 mph top speed. How much power do we need for that
    Unitronic 1+ ECU/TCU: Tyrolsport Deadset Subframe locking kit: ECE Rear Motor Mount : Unitronic 4 inch turbo Inlet : APR Ignition Coils : VTT Silicone Charge Pipes : NGK Race Plugs : Whiteline Rear Sway Bar : 034 Motorsports mid-pipes : 034 Open Carbon Intake System : CTS Intercooler : 20% Suntek Ceramic Tint
    Apr 30 2015
    Michigan
    Awesome. Thank you.
    This is a great sheet.
    Jul 13 2018
    When you hear the RS3 has a 7 speed trans, you assume it has some tightly spaced cogs. However, only 1 to 4 are really the acceleration gears for most, with 5 to 7 for cruising.
    I'm not an engineer butnit would have been nice to have the 4th ratio closer to 3rd.
    Jul 24 2018
    Westlake Village, CA
    Quote Originally Posted by TheContrarian View Post
    On the high hp cars, that 4th gear really makes the car move, giving the MPH in the 1/4 and 1/2....
    Jan 16 2018
    Midwest
    Quote Originally Posted by allerum View Post
    Taking a SWAG at my desk using S3 frontal area with RS3 Cd, only ~620 hp.
    @surprs3
    Jan 16 2018
    Midwest
    As requested from a member.
    @surprs3
    Jun 01 2007
    NOVA
    It looks like this URL disappeared..any chance you still have this?
    Sold // 2018 RS3 - Unitronic TTE700 / BoostLogic / 034 everything / BBS RI-A / etc
    2023 SQ5 - stock + BBS CI-R
    2024 Wrangler 392 - BC Forged LE81 + 37" KO2
    2009 Corvette Z06 - HCI / BC Forged MLE215
    May 02 2019
    Dec 22 2019
    Sweden
    I found this a while ago. I don't know how accurate it is. Seems a bit high... Perhaps this is what's shown on the speedometer, which in that case means that the real speed would be a bit lower.
    I do know that at high speeds (250 kph and above), the speedometer (with oem tires) shows exactly 10 kph too high, and it seems to cap there. I have seen mulitple runs on youtube with 290 indicated (280 real) and a stage one RS3 with 318 indicated (308 real).
    Established Member Two Rings Nartard's Avatar
    Apr 09 2019
    N.KY
    Quote Originally Posted by Zeruel View Post
    Just looked back at some Dragy videos I have from the strip - the shift points are within 1mph of my car. The biggest delta was 4-5 shift, mine happens right at 125 mph, not 128. Super close in any event.
    Jan 16 2018
    Midwest
    Quote Originally Posted by cseaman View Post
    I lost track of this thread, sorry about that. Let me try posting it a different way since it’s disappeared twice now.
    @surprs3
    Junior Member Two Rings
    Jan 30 2020
    Parker CO
    Would you mind sharing this excel sheet?
