Results 1 to 24 of 24
    Aug 19 2019
    texas
    Audi a4 b6 electrical
    So the other day my AC decided to shut off. It would only turn on with defrost on. No instrument lights on my dash worked after this but the instruments still worked. Later on that day i pulled the instrument cluster fuse. The AC worked as it should. If i out the fuse back in it would shut off and only work with defrost on.
    Emergency button and AC controller stay illuminated when car is locked
    That being said i replaced every single fuse on the panel and replaced the "370" relay. Issue still happens. I am at a loss and have o idea what else to do.
    Aug 19 2019
    texas
    Anyone have any insight. I replaced the instrument cluster. The singals came on 15 minutes later but stayed solid and one stayed on after the car was powered off
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Have you verified power at the compressor? What are the high and low side pressures?
    You win some, you lose some...
    Aug 19 2019
    texas
    i have not, but recently I have lost all power to controls and the instrument fuse no longer receives power. AC is working 100% now, but I do not have wipers, cruise, headlights, night time running lights, locks, or windows. Im assuming theres a ground issue somewhere? as I stated ac is working operating 100% but there is no power at the fuse itself for the instrument cluster.
    Aug 19 2019
    texas
    Ive been searching for a wiring diagram for the fuse to see where it leads, I figure there is either a fried ground, or power at this point.
    Jul 10 2015
    Colorado
    Electrical portion of your ignition switch? Not too hard to change out.
    Aug 19 2019
    texas
    ive changed the whole ignition switch itself. ill have to trace the wiring to see if I can find some burnt wiring
    Established Member Two Rings TimelessB6's Avatar
    Mar 11 2018
    D3 W12, Noggy B6 S4, 957 Cayenne GTSx2, Triumph TR6R
    Tolleson, AZ
    Bump. Having a similar issue.
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Scanning your control modules for fault codes would help narrow it down. Have you noticed any water on the floor after heavy rain?
    Aug 19 2019
    texas
    vag com no longer reads it after it lost power, no water. I have checked the CCM looks brand new. the instrument cluster fuse no longer receives power
    Aug 19 2019
    texas
    Does anyone know where all the grounds are located for the fuse box? I am going in tonight to check more wiring
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by Colby702 View Post
    Click
    Aug 19 2019
    texas
    Soooo. I havent found a bad ground but since i cant read ccm or steering colum with my vag com. I ran it for the dashboard. Same codes i was reading prior to the complete loss of communication to steering colum and ccm.
    01331
    01330
    00457
    01320
    00466
    01333
    01334
    01332
    01331
    Active Member Two Rings Jonamond's Avatar
    Jun 11 2016
    09 Ford Flex, 02 Honda Civic
    Woodstock Ontario
    can you communicate with any other modules besides the cluster?
    Aug 19 2019
    texas
    i cant communicate with the steering module or the instrument cluster. used to be able too until recently
    Active Member Two Rings Chris60M8's Avatar
    Feb 20 2019
    Fort St. John, BC, Canada
    What kind of voltage is the battery putting out?
    2004 Audi A4 B6 Ultrasport - Quattro, 6MT, 1.8T, Dolphin Grey Metallic
    1983 Porsche 944, ROW model, 5MT, 2.5LNA, Alpine White
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    Here is the B6 electrical diagram:
    https://ufile.io/f293fh06
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Aug 19 2019
    texas
    Just giving an update. Mechanic has said there is a total system failure (we know this) still no leads obd2 states the alternator is charging right and battery is brand new.
    Jan 24 2010
    Paramus,NJ USA
    Sounds like water intrusion into J393 or failure of J519. Could be either one. I would check for water under the carpet. If no water Change J519 and report back.
    Ziddy Autowerks
    Aug 19 2019
    texas
    If i was to replace either of these, as long as i pull the same part # would it be a direct swap. or is this something that will need to be coded?
    Aug 19 2019
    texas
    Just curious about j519. This is vin locked. Does a replacement need to be directly from another 1.8t or just similar year ? I have a buddy with a free vin on his rosstech. Can it be flashed and recoded through this?
    Aug 19 2019
    texas
    Here’s my autoscan
    Wednesday,21,October,2020,21:16:14:00648
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WAULC68E54A179902 License Plate:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAULC68E54A179902 Mileage: 249290km-154901miles
    Address 01: Engine Labels: 06B-909-518-AMB.lbl
    Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0004
    Coding: 0016711
    Shop #: WSC 78391 537 435974
    VCID: 79ACE43155C97A4315D-5160
    4 Faults Found:
    18043 - Powertrain Data Bus
    P1635 - 008 - Missing Message from A/C Controller
    18107 - Powertrain Data Bus
    P1699 - 008 - Missing Message from Steering Wheel Electronics
    17072 - ECM Power Relay Load Circuit
    P0688 - 004 - Open Circuit
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04275
    Shop #: WSC 06435
    VCID: 2616FF4DF1F725BB08F-51F2
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AC
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63351
    VCID: 629EA35DDD5F999B247-513C
    6 Faults Found:
    01273 - Fresh Air Blower (V2)
    30-10 - Open or Short to Plus - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    49-00 - No Communications
    01330 - Central Control Module for Central Convenience (J393)
    00466 - Control Module for Steering Column Electronics (J527)
    00457 - Central Electronics Control Module / BCM (J519)
    00474 - Control Module for Immobilizer
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    Shop #: WSC 63351 000 00000
    VCID: 3FD84A290B6D94736B9-5184
    4 Faults Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
    001 - Upper Limit Exceeded - MIL ON
    00588 - Airbag Igniter; Driver Side (N95)
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    004 - No Signal/Communication - Intermittent
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 P
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01231
    Shop #: WSC 02121
    VCID: 36362F0D2157553BB8F-5160
    WAULC68E54A179902 AUZ6Z0C0430969
    12 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    29-00 - Short to Ground
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01334 - Door Control Module; Rear Right (J389)
    01333 - Door Control Module; Rear Left (J388)
    01320 - Control Module for Climatronic (J255)
    01336 - Company Data Bus for Comfort System
    37-10 - Faulty - Intermittent
    01304 - Radio
    End----(Elapsed Time: 06:12, VBatt start/end: 11.4V/11.5V. VIgn 11.5V)-----
    Jan 24 2010
    Paramus,NJ USA
    Still looks like water intrusion in J393 or J519 as I mentioned earlier roughly 6 months ago. Did we verify there is no water in ebox or J393 and J519?? J519 supplies power to majority of the circuits in the car J393 can take alot of those circuits down if shorted or under water as it talks to alot of system in the car including cluster ac and so on.
    Ziddy Autowerks
    Aug 19 2019
    texas
    I’ve replaced j393. No change. I’m going to buy another j519 here soon. As long as I get the same model, it should be plug and play no?
