Originally Posted by
spike6339
Hey, I hate to bump an older thread.... But Ive been searching forums, and can't seem to make up my damn mind on the best setup. I picked up some 20's for a decent enough deal, and they got wrapped with some super super thin sidewall tires. The Current setup is 230/30/R20, and the wheel is 20x9. The tire is far too low pro for my liking, and I wanna go a bit thicker on the sidewall. What would be the best setup for wanting to eat up some of the wheel gap on a 2013 A4 non S-line? Currently a stock suspension setup, but wouldn't mind going a little lower in the future. I've been leaning towards a 245/35/r20 tire, but not sure if i'll run into any issue with rub. People say you may get rub with 255's, so i'm not sure how people even talk of a 275
Current setup:
62223660536__2D8A397C-5259-43D1-A833-A57131B815C3.jpg62223661405__CE5807EF-2DF0-4CE8-87DF-AF4AB6B71273.jpg
oh yea those are definitely too thin lol. so for comparison my setup is 19", 9.5 wide with et35 offset, and i run 255/35 tires. i'm lowered also, i don't rub at all but i'd say i'm close to, 255 is prob the widest i could go on my current setup.
but for you since you arent lowered, and those are 9" wheels, you could go up to 265/275 if you wanted. i think 255/35/20 would be a good size, that will be a nice squared setup on 9" wide, no stretch. 265 would give you a slightly more bubbled out/meaty look if you prefer that.
- 255/35/20, this will give you the 19" tire thickness, but you may not be able to go too low with this, just a slight S4 level drop maybe but not too low, but it would be great for now to add some tire thickness and fill up that wheel gap a little more. but FYI 255/30/20 is the OEM option on the S4 with a 20x9, so it would work too and definitely wont be as thin as your 235/30.
- 265/30/20, i think this is a good middle option. slightly more meat than the OEM 255/30, would be the best option if you were lowered and won't have to worry about rubbing.
- 275/30/20, should work fine for now too, you can go 275 without rubbing, even if you slightly lower it later on i dont think 275 on a 9" is wide enough to rub anyway. i believe 275/30 is the OEM size for the RS5 and other models.
