Results 1 to 26 of 26
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Downpipes and mid pipe discussion...
    Hey guys, I've had the car a week now and am ready to improve on the stock performance. I have ordered Unitronic Stage 2 software and will run the Stage one until I accumulate the parts needed for stage two. In the past my S model cars all came with great flowing exhaust and most of the time upgrading exhaust was more for sound than power. Is the exhaust on this car actually restrictive at the downpipe and mid pipe sections or is this more of a trend to sell more parts and be louder? Is there any before and after dyno charts that show a justifiable improvement? My goal with this car is to keep sound as close to stock as possible but make stage 2 power, if that is an impossible feet and I have to upgrade downpipe and mid pipe then so be it but if I can get away with just downpipe or just leaving it stock and upgrading intake and intercooler that would be ideal. Also if anyone has tuned out or has a solution to stop the start up crackle I would love to see that gone. I wish they would have made that only happen in dynamic so you at least had the option to not turn everyones head your way when you start the car. Thanks for any insight on these inquiries.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Well you can't run the stage 2 tune with a factory downpipe soooooo
    Feb 09 2016
    co
    You can make close to stage 2 power on Stage 1 E85 tune, without needing DP.
    I ended up going the Stage 2 route since i'll only run 93 oct and had to get DP.
    I've been seeing a few people run stage 2 without aftermarket DP, however, looking at both units side by side, i'd guess there is definitely a restriction in the stock DP.
    If wastegate rattle is a concern, you can try IE or APRs catted DP to minimize the wastegate rattle but i hear it's still pretty noticeable.
    As for the loud startup, i just ordered exhaust valve controller to address that. It lets you control if you want flaps open or closed on startup.
    May 26 2008
    MD
    Quote Originally Posted by LJS5 View Post
    Yeah but he already purchased Stage 2...
    Feb 09 2016
    co
    Quote Originally Posted by Evilevo View Post
    I was under the impression that Stage 2 purchase include all of stage 1 maps as well. I upgraded from stg 1 -> 2 so not 100% sure.
    Just throwing it out there if it's available, OP can just flash the Stage 1 E85 map for maximum gains while retaining stock sound.
    Nov 12 2006
    Michigan
    Thanks for the info, do you have a link for the exhaust valve controller you are using?
    Feb 09 2016
    co
    Quote Originally Posted by elijahallen View Post
    https://europrice.us/controller-pack...-exhaust-valve
    Aug 04 2018
    Montreal
    Will any mid-pipes void the warranty ?
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Quote Originally Posted by Gamil View Post
    It's up to your dealer. Only way to know for sure is to ask them about it. Some will care and some won't.
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    As for the power of S1 over S2.... that will vary from tuner to tuner but I can tell you that there are nice gains to be had over the UNI S1 with the UNI S2 tune. The online documentation makes it look like a difference of only 20HP but that isn't reality. That restrictive primary cat sitting just aft of the stock turbo (which is being run at 100%) in the stock downpipe is not only a bottleneck for airflow but also a device that creates back-pressure as well extreme heat in an unwanted location. It is not optimal for performance. The down stream secondary cats in the midpipes are more free-flowing and thus are actually the last restriction would worry about. Be advised aftermarket midpipes provide no performance benefit on their own. However, some claim the car gets 10% louder and other claim that removing the secondary cats actually reduced the crackles.
    A catless downpipe does have some downsides, it will be much louder (some may like this), you will hear that notorious wastegate rattle that sounds like a major exhaust leak (Seriously sounds like your car is a POS) and on pump gas you will smell exhaust fumes especially with any tune that leverages injector overrun to provide those attention starved folks pops and bangs.
    From what I can tell the gap between S1 and S2 broadens as the weather gets cooler. Uncorking the exhaust makes a huge difference when you can actually move more air (airflow). You should take a look at the 1/4 mile database and review the MPH differences between S1 and S2 cars. Yes there are supporting mods, weight and weather differences but you can clearly see the differences.
    Before I purchased the car I was 100% sold on going catless but that was until I heard the WG rattle. I just couldn't deal with that on a daily basis. This knowing there is more than likely 30whp on the table by going S2.
    Jun 02 2018
    I put the Uni midpipes on yesterday. Stage 1+ tune with Iroz intercooler. I would say 20-30% louder with no change in tone. I'm very much liking it; still quiet in comfort mode but in dynamic and sport it's like turning up the volume a notch or two on your favorite song. Pops on downshift seem about the same but you can hear more of it now so perceptually it's an increase to me.
    Nov 24 2018
    Madison WI
    If you want to know what wheel horsepower is for a UNI S2 E85 car below is a dyno of the lapping day (dialed back) tune, the standard tune and the standard tune with the stock intake box disconnected meaning no filter.
    Aug 03 2019
    Do i have to get mid pipes from a company? Why cant i just go to a exhaust shop and have them cut off the secondary cat and weld a pipe in?
    Is there any difference?
    Nov 12 2006
    Michigan
    Quote Originally Posted by mahmutRS3 View Post
    Its illegal so most shops will not do it.
    Jul 13 2018
    Winnipeg, MB, Canada
    Reversibility is a nice feature.
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by Chris F View Post
    This is my experience as well.
    Senior Member Two Rings shifu22's Avatar
    Aug 28 2016
    B8-S4, MK3-TTRS
    Coquitlam
    Midpipe and downpipe makes the car sound amazing! It’s something you should definitely do. I’ve done it and I have had no issue with warranty.
    B8-S4
    MK3-TTRS
    May 01 2016
    Central Florida
    Here is a short clip of my TTRS with going by at about 125mph WOT with cat less midpipes.
    https://www.youtube.com/watch?v=JWFJ5qM0F6s
    2023 Kyalami Green RS3
    2022 Dodge Durango SRT (Daily/Hauler)
    2015 Harley Road Glide
    2024 Aprilia Tuareg 660
    Aug 04 2018
    Montreal
    Just installed OEM midpipes, that's really a nice sound !
    And still quiet in D mode.
    Dealer told me I might get a check engine light at some point, due to lack of cat. Anyone got that ?
    Jul 25 2010
    WI/IL
    Catless midpipes won't give you a CEL. Downpipe with no cat and no tune will.
    Aug 04 2018
    Montreal
    Quote Originally Posted by jl87 View Post
    Yeah that's what i thought at first before doing it, I was just not expecting that from the dealer ???
    Anyway it doesn't really matter now :)
    Sep 03 2019
    Italy
    Quote Originally Posted by tateltot View Post
    Extremely happy to hear that the Uni midpipes produce good results. I just bought them last night.
    Aug 07 2019
    Toronto, ON
    Quote Originally Posted by shifu22 View Post
    Lucky your dealers are cool with adding the catless OEM mids
    Spoke to my dealer today and he basically said they're not sure if they'll do the mod and even if they do it could void warranty
    I asked how an Audi OEM part could void warranty
    His reply: It's not original for NA vehicles and therefore may not coordinate with the "NA tune"
    Aug 04 2018
    Montreal
    Quote Originally Posted by xliv View Post
    yeah indeed, I was lucky not getting this argument... I just showed them the bill from the Audi dealer in Germany, and they installed without question. On the work order it is written "OEM Germany parts provided by the customer".
    Nov 24 2018
    Madison WI
    You can always buy someone's catted mids and smash the honeycomb out with a pipe. Then you would have catless mids with a 100% OEM appearance.
    It's too bad catless mids don't actually recover any horsepower.
    Aug 07 2019
    Toronto, ON
    Quote Originally Posted by Jeff_Jeske View Post
    Good idea as they would likely never check.
    Unfortunately got a confirmation from my dealer today that they won't swap out the catted mids as they haven't done it before and don't want to risk voiding warranty
    Now speaking to Audi Canada to have them coordinate with the dealership to establish whether or not this swap actually voids warranty... Again the argument I'm making is they're both genuine Audi parts that don't materially change the flow, back pressure, or throw any codes so one would expect the warranty to remain intact
