Originally Posted by
buza79
Hey,
I have a C6 RS6 and unfortunately the disc/rotor prices are pretty exorbitant regardless of whether you go OEM or aftermarket; in terms of aftermarket options you could try the two piece AP setup (meaning you just replace the outer rings when its time to replace the rotors). In terms of brake pads you can go OEM with BREMBO which will set you back between $100-125 for the fronts and between $60 and 80$ for the rears, which appears to be the cheapest option among the respected brands. I know a lot of guys swear by Ferodo DS2500 and some guys run Pagid but both these options are far more expensive than OEM particularly for the fronts, but are supposed to give far better stopping power. The draw-back of increased stopping power is that they chew through the discs/rotors lot quicker. Hope this helps.
Thanks for the reply. Do you run the Brembos as well? Curious what the part number is. Are they shared with any other vehicles? I keep having trouble finding the exact fit “compatible” models, hehe.
I was considering the AP rotors, but I’m not sure how long I’m keeping the car - I expect a set of rotors to last me ~50K+ kms, and I don’t put a lot of mileage on the car so that could actually last me almost 8 years - who knows what I’ll have by then, I could go bankrupt feeding it gas in the meantime. lol. So in that sense, any idea of compatible non-OEM options, or should I just bite the bullet?
