    Dec 18 2008
    2015 Audi Q5
    Denver
    Running 265/40/20 for winter setup?
    Is anyone running 265/40/20 for their winter setup on the S7? Any issues? I figured it would be nice to have that little extra sidewall for those winter potholes!!!
    Oct 08 2012
    Bloomfield Hills
    Glad you asked abou this!! I did this last winter with my 2016 A7 on the 19 inch rims size 265/40R19 and it was a HUGE MISTAKE. The tires were too wide and they hydroplanned and plowed over the slush snow rather than digging through it during winter storms. I had the Michelin Pilot Alpine PA4 N-spec and I am selling them after 3 months of use and going back to Blizzaks size 245/45R19 on my 19 inch winter rims. THey were amazing compared to the wider 265 profile Michelins. I store my 20s with Michelins Pilot 4S for winter. Do not get the size 265/40R20 it will also rub on full turn too since sidewall is too high for your 20 inch rims. I would downsize to 19 inch rims and get a set of Blizzaks WS-90.
    Mar 30 2018
    long island
    i did 255/40/20 on a rs7, offset 20 wheels.
    I get a little bit of rubbing, due to the low offset.
    you may be safe from rubbing, but your speedometer will be slightly off
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Mar 03 2019
    Sioux Falls, SD
    @Rexus300. I have an 18 A7 with 265/35r20 as stock tires with 20x9 wheel. I also plan on using 245/45r19 Michelin x-ice or Blizzak for winter here in South Dakota. I plan on buying a Hartmann 19x8.5 wheel, but not sure if I should ET25 or ET38 as they state both will fit A7. What wheel did you choose for winter setup. Any advice?
    Dec 18 2008
    2015 Audi Q5
    Denver
    Looks like 255/40/20 would work well because of the skinnier tire width with a little extra sidewalk. Might try that out.
