Page 1 of 5 123 ... LastLast
Results 1 to 40 of 167
    Veteran Member Three Rings ALLROADINGB9's Avatar
    Jan 23 2017
    Westchester, NY
    Nogaro Blue B9 Allroad Build Thread (1/1)
    Many of you may recall my prior build thread, I decided to start over as I felt the need to restart the thread, as it was starting to look like a drama journal
    So this is my build thread-
    --1/1 8W5HNY B9/8W A4 Allroad.
    --Nogaro Blau Pearl Effect, full body paint (Q0Q0)
    -Standard Molded Roof Liner- Soul Black (A.E option)
    -Black Interior with blue contrast stitching.
    See attached window sticker-
    Attachment 139169
    My modifications are not limited too, but include the following-
    (This list is always on going and I will try to keep it as new/refreshed as possible )
    -TAG Motorsports "OEM +" Black optics painted factory grille
    -Full black optic window trim, including C/D pillar windows, 8 window trims, RS4 Roof rails.
    -RS4 Spoiler
    -European front bumpers
    -Blue stitched 8S TT S Flat Bottom wheel, w/ Audi Sport Carbon fiber Shift Paddles
    -BBS CH-R 20x9 ET25 (Credits to Nima@Nemesis and Mops@Nemesis )
    -Alcantara Shift Cover
    -European Style Rear Headrests- Low profile
    -Cargo Rail Organizing System in the rear trunk, with built in storage for the partition, and adjustable eyelets
    -KW/ABT H.A.S System, with factory EDC dampers
    -034 P34 CAI
    -034 Line of Powertrain upgrades
    -CTS Turbo FMIC, Charge Pipes
    -Milltek Fully Resonated cat-back
    -Alcantara Door panels
    -RS4 Door handles (Interior)
    -Led Glovebox Light
    -"Heartbeat" chime at startup/stop
    -APR + Stage 1- Patiently waiting for their DSG Flash if one becomes available
    -Audi Exclusive Badging on door panels
    -More I'm not thinking of lol
    It's been a long process to getting the car, but the patience and pain ultimately was worth it!
    -C
    Jan 23 2017
    Westchester, NY
    Of course this thread wouldn’t be valid without any pictures!
    Feb 26 2009
    Darmstadt, Germany
    How did you get the "Heartbeat" chime?
    Do you have any sound clips of your Miltek exhaust?
    Did you change the lighting in the trunk?
    Do you have a pic of your RS4 spoiler?
    Thanks
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by BettaJetta View Post
    Thanks
    1- VCDS coding-
    Unit 5F
    Adaptation
    Activate channel "Vehicle configuration-vehicle_readiness_sound"
    Enable
    2- Installation is soon, will be sure to provide some sounds :)
    3-No lighting changed In the trunk. Added a canvasback cover that was custom fabricated to work with my cargo rail system.
    4-
    Sent from my iPhone using Tapatalk.
    Jan 23 2017
    Westchester, NY
    Well, the car is going under the knife tommrow for the following components to be installed :)
    -RS4 Black optic Roof Rails
    -Black optic window trims, C/D pillar windows
    -Black optic painted grille, CTS turbo FMIC, charge pipes.
    Once that phase is completed, it’s time to stop, drop and roll! ;)
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by ALLROADINGB9 View Post
    1- VCDS coding-
    Unit 5F
    Adaptation
    Enable
    Did you post a video with the sound? I'm assuming it's when you start the car and is the sound I'm thinking of from the Audi commercials?
    2018 A4 | Mythos | Prestige | S
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by JBAeroEngineer View Post
    https://youtu.be/2fQtsaFL_sg
    Sounds just like this :)
    Sep 19 2012
    Capitol Area
    Cool. The VCDS thread needs updating!
    Can't wait to see that grille installed!
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by vividracing View Post
    Should be soon :)
    Jan 23 2017
    Westchester, NY
    Should be soon :)
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    Should be soon :)
    Stop all this IG and start building the car already!!! Or you not gone get that painting 🖼 😉😘
    Prestige B9 SQ5 / Moonlight Blue / S sport / DAP / Dynamic Steering
    JB4 Tuner / ROC-Euro Intake / Lowering Links / 034 Trans Insert / V-FF 109
    / Brembo GT 380mm / AWE Exhaust /
    Build Thread | Instagram @_kademan_v60cc_ | YouTube @MK2 SQ
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by MK2SQ View Post
    Jan 23 2017
    Westchester, NY
    Here’s a little sneak peak :) next round is to have the door handles, European bumpers, and RS4 spoiler painted, as well as replacing the rear window glasses.
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    Why?
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by volcomic View Post
    Why?
    The trim on the glass is permanently attached to the window, in order to complete the retrofit, I have to swap them out.
    Senior Member Two Rings unitzero's Avatar
    Nov 09 2011
    UK
    Would it not be easier and cheaper to just wrap or paint the trim ?
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by unitzero View Post
    Yes! But the factory black optics is something I didn’t want to settle with ;) go big or go home.
    Nov 09 2011
    UK
    I thought so. Keeping it OEM all the way, I can respect that, looking forward to seeing the progress
    Bagged Daytona B9 Avant
    instagram :@_baz
    Aug 11 2018
    Looks better every day!!
    Jan 23 2017
    Westchester, NY
    Been a little quiet in here ;) black optic grille, roof rails, window trims are in.
    Aug 11 2018
    Jan 23 2017
    Westchester, NY
    All about the details
    Aug 11 2018
    Jan 23 2017
    Westchester, NY
    Black rings, RS4 spoiler installed.
    Great day at Limerock for avantoberfest.
    Active Member One Ring AkitaNL's Avatar
    Sep 04 2018
    The Netherlands (EU)
    Have you only placed the badge, and so yes, how? Or have to replace the complete upholstery? (Btw, send you a FB messenger message )
    Jan 23 2017
    Westchester, NY
    The badge was attached with a self locking washer from behind. The door panels have these dots, that indicate where the badging attach.
    Quote Originally Posted by AkitaNL View Post
    Jan 23 2017
    Westchester, NY
    Pics not working
    Jan 23 2017
    Westchester, NY
    I plan on getting all of the satin silver trim painted to match the rest of the car in Nogaro blue. Will give it much more of an avant vibe :)
    Also photoshopped it lowered expect that soon.
    Jan 23 2017
    Westchester, NY
    The first B9 Allroad in the world with the ABT HAS adjustable springs. Car rides like a dream, and the adjustability is excellent to have when I move out of winter mode.
    The stock bump stops for the rear struts where used instead of the ones from ABT, because it limited suspension travel and didn’t allow the shock to fully compress. Otherwise, everything was straight forward and installed :)
    Thank you to @mops@nemesis and Nima for outfitting me with the best suspension around for these cars, and dealing with my questions ;)
    Jan 23 2017
    Westchester, NY
    Added these “allroad” puddle lights from the 20th anniversary edition C8 A6 allroad.
    Reminiscing of Avantoberfest 2019 :)
    Mounted the factory wheels for winter driving. Really happy with the ride height.
    Dec 08 2019
    Sweden
    1- VCDS coding-
    Unit 5F
    Adaptation
    Enable
    4-
    Where did you buy the spoiler?
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by Juggeskog View Post
    I got it from a seller in Germany.
    Part number 8W9827933BGRU
    This comes primed, with the 3rd brake light and associated wiring. Just needs paint and it’s ready to go :)
    Dec 08 2019
    Sweden
    Sounds good, do you possibly got a link to the seller?
    Was it bolt on or did you have to make any modifications for it in order to fit? :)
    Senior Member Two Rings LaZyB0ne's Avatar
    Mar 16 2019
    San Diego, CA
    It's a direct fit, no modifications were required.
    Junior Member Two Rings
    Aug 11 2019
    2002 Audi TT ALMS
    Crystal Lake, IL 60012
    Can you share more details about the cargo rail organizing system? Part numbers? Source?
    Jan 23 2017
    Westchester, NY
    Quote Originally Posted by cue View Post
    B9 Cargo Rails (L AND R)8W9863555 and 8W9863556
    Cargo Lashing Points for Rail System 4M0863539 (4)
    Retractable Cargo Managment Guard 4M0860378C (1)
    Metal Extendable Piece for Rail System 4M08603784PK (1)
    Aug 11 2019
    2002 Audi TT ALMS
    Thanks for the QUICK reply. I did a search on E-acca.com but unfortunately, most of the parts are not available. The only one that was is the metal extendable piece. 174 EURO
    I did find some of them on audiusaparts.com, but the rails are not available from them either. The rest of the parts that were available were $500+? So, I'm guessing this cost you about $700 total?
    Jan 23 2017
    Westchester, NY
    Let me try with updated part numbers
    (1) 4M0 860 378 4PK
    (1) 4M0 860 378 C 4PK
    (4) 4M0 863 539 4PK
    (1) 8W9 863 555 4PK
    (1) 8W9 863 556 4PK
    Sorry about that!
    Jan 23 2017
    Westchester, NY
    New custom painted “Black Optics” valence. Since no genuine black optics variation was available, I sent this one to TAG Motorsports for the finishing touch.
    Will be getting the side sills, and front valence in silver painted shortly as well. Though for those pieces, I will have it painted in Nogaro Blue, to give the car more of an Avant Vibe.
