Originally Posted by
unaimed1337
You are talking about fully circulating car with presumable AC on and heater at full blast. Of course it makes a difference, however if the car is turned off, what difference would the pump and fan for the SC heat exchanger make?
Don't you see it just doesn't make any sense? How long do you want the fan and pump to run? 10 minutes? Then it's gonna still heatsoak after 15 minutes etc. To stop the heatsoak you would essentially have to equalize the temperatures through the engine compartment.
The whole idea just doesn't make any sense, unless you always shut the engine off for 10 minutes, it's a pointless exercise.
You obviously have no idea what you are talking about, first of all please read how actually OBD2 works from the programming side (hint: it's a querying protocol). And then finish it off with how for instance Android handles bluetooth and how much delay is inserted by the OS itself (there are couple interesting benchmarks for bluetooth audio).
Yes, for 5 minutes, after that it will still heatsoak away.
Urgh, the OS`s load, in terms of ressources, is directly related to the CPU power (and memory available). Run 2 OSs, one with a weak CPU, it will consistenly run at 90-100% of usage, where as, if you run it on a powerful CPU, with the exact same settings and configuration, it might run at 5% or less. When your CPU is running above 90%, it automatically start to drop packets. Add to that the BT protocol limitations, the ppor design of smartphone apps, and the fact that these phones are doing many more things than just capture your data logs for your car, and you end up missing a lot of results.
If you want proper logs, use a powerful laptop, with a professional interface/application, which are all purely dedicated to logging with absolutely the bare min running in the background.
Am gonna say it again: if ur using a phone, ur doing it wrong.
